What should my MAP be at idle?
Old Jul 3, 2005 | 05:05 PM
DVNCI's Avatar
DVNCI
Default What should my MAP be at idle?
I'm getting about 70 Kpa which seems too high to me?
I have stock displacement but ported heads & intake.
Cam is 230/242 at .050 with a 112 LSA
Is my MAP sensor going bad???????
What else could cause it to be this high? I know a big cam will pull more kPa but this much?
Old Jul 3, 2005 | 06:16 PM
Zix's Avatar
Zix
I have a 242/252 cam and my MAP sensor reads about 20 In/Mercury, which is almost exactly 70Kpa, so I would say your MAP sensor is reading fine.
Old Jul 3, 2005 | 07:37 PM
STL94LT1's Avatar
STL94LT1
224/230 605/622 112, and my MAP KPa at idle is 58-60. It definately took a little tuning to lean it out at idle, with these MAP readings. Stock was 32-33 KPa.
Old Jul 3, 2005 | 07:52 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Your ok, it sounds like you have a auto and you have some tuning left, but your not too far off now.
Old Jul 4, 2005 | 04:18 PM
ZD1's Avatar
ZD1
with your disp and cam I'd say "good job" getting to 70%, if you do put in a higher stall TQ (are you auto?), you'll find that your idle Map point will lower. I'm running a .600" lift 224/230 383 at 55-60 kpa at 900 rpm idle
Old Jul 5, 2005 | 01:18 AM
DVNCI's Avatar
DVNCI
I'm manual but the figure I'm quoting was with a 750 idle, it was just too low so I took it back to 925 (from my original CC 306 program). I'll log it tomorrow to see how that affects it.
Old Jul 5, 2005 | 09:32 AM
Nathan Plemons's Avatar
Nathan Plemons
With the Hot Cam my MAP is around 50 at idle, 30 or so is stock.
Old Jul 5, 2005 | 02:41 PM
Rohn's Avatar
Rohn
226/230 @.05 114 LSA. 35-40 map @ 800 rpm. manual trans.
Old Jul 5, 2005 | 03:17 PM
hippy's Avatar
hippy
About 55 @ 900 rpm idle with a 219 cam.
Old Jul 5, 2005 | 03:20 PM
FD2BLK's Avatar
FD2BLK
I have right at 60 with the 383 and 306 cam at a 950 RPM idle.
Old Jul 6, 2005 | 07:42 AM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
40-45 KPA at Idle (825RPM) with 214/221 0.505 / 0.540. 355 CID.
Old Jul 6, 2005 | 04:52 PM
DVNCI's Avatar
DVNCI
I took my idle back up to 925 and it dropped to 65 or so - so I guess that's about right.
Thanks everyone!
To What should my MAP be at idle?
