700 raptor trans question
Old Jul 4, 2005 | 11:24 PM
CaptainCaveMan's Avatar
CaptainCaveMan
Default 700 raptor trans question
I did a search and saw someone say not to shift to 4th WOT in a 700 auto trans. I have a level 3 raptor in the vette i just bought and i want to make sure i'm not on my way to destroying a transmission.
Am i supposed to floor it through the 1-2-3 shifts and then let off, shift to 4th and then floor it again to keep gaining speed?
Yes, i'm a newbie at this transmission stuff. I'm not used to shifting automatics and i can't say i'm to fond of it.
Old Jul 5, 2005 | 04:33 AM
Fubar569's Avatar
Fubar569
i have a presumably stock (with a shift kit) 700R4 in my 84...and i keep the pedal to the wood the entire run till she ain't got none left...it shifts hard and crisp and i put this sucker through a ton of abuse...still runs great after about 40k of service...
Old Jul 5, 2005 | 10:50 AM
MrNuke's Avatar
MrNuke
I was told that the 3-4 shift is VERY tough on the tranny if you have some power behind it. If your car is stock, I doubt it is bad enough though..
Old Jul 5, 2005 | 01:39 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
Actually a vette is the only car in which you CAN go to 4th at WOT. The standard 700R4 has a valve that prevents that shift at WOT. There is a 'corvette only' part that allows it to happen.
If it is an issue of having too much power, I wonder why they add a part to the tranny to let a vette do it, but keep all of the other vehicles (with the 700R4) from shifting.
Old Jul 5, 2005 | 05:05 PM
4bblC4's Avatar
4bblC4
That's usually something that you don't want to do with ANY 700r4 tranny (with lots of torque).
why don't you talk to transmissioncenter about it???
To 700 raptor trans question
