A little back ground before the questions....I have a 94 six speed that I use for auto x and a weekend driver. I have EM long tube headers, Random Tech cats and a Corsa system on order. Cut lid, K & N and Big Mouth Air Dam are already on.
I don't want to go all the way into the engine yet. That's next years' project. Is it worth pulling the valve covers and changing to the 1.6 rockers to get a little more lift out of the stock cam? Does the ECM need to be reflashed for that? Which are a better bang for the buck, the true roller rockers or just the roller tipped rockers? There's a fair amount of price difference between the two. And which will fit under the stock valve covers? Should I just wait until I pull the engine to bother with the rockers?
I don't beat the crap out of it but it is driven kind of () hard at the track. The rebuild will be fairly mild when I do it next year to stay legal in NCCC Group II. So this won't be any 600+ HP monster. Probably end up around 350 - 400 at most.
Can't do either I just found out. NCCC won't allow internal mods to Group II cars. Even when I rebuild it the cam lift and duration has to be stock. So I can't play with the ratio on the rockers. Oh well.
Most of the friction is in the fulcrum. Full roller rockers are the way to go.
Please enlighten me.
How much friction, is there, at the fulcrum of
a standard rocker in the SBC?
Or, better, how much energy is lost in
the fulcrum over one cycle?
I sorta don't believe the typical seat o' pants - dyno
or oil temp comments.
Could you at least buy a quality OEM style rocker with the same ratio.
I have heard GM's ratios stock can range all over the board!
I often see a 5-10 degree in oil temp with the install of full roller rockers. This alone makes it a worthwhile addition.
What, you don't beleive full roller rockers improve performance?? It has been documented in about every magazine out there. Stock rockers don't hold up to high lift cams with high spring pressures real well either. I have seen plenty of stock rockers with the bottoms blown out. I wouldn't consider stock rockers in any sort of real performance engine build up, except for a very mild low budget engine.
Could someone do a calculation, please.
Normal spring pressure, cam lift,
oiled-steel-on-steel coefficient of friction, etc.
I just don't believe that rocker-fulcrum
friction is significant, compared to
piston ring friction.
Negligable. A good set of stamped rockers with grooved pivot ***** have very little friction loss AND will last much longer than alumnium full rollers.
