fan switch and thermostat?
Brad
A thermostat is not wide open at the stated temp of the thernmostat. A 180 thermostat should remain closed and not even start to open until the coolant temp reaches 180F (plus or minus a couple of degrees due to manufacturing tolerances). A thermostat should be wide open at its stated temp plus 20F. So a 180 thermo should be wide open at 180F + 20F or 200F (plus or minus a couple of degrees). For reference see section 6B in your Helms Factory Shop Manual where it describes how to test for a properly working thermostat. You can also talk to the STANT technical people as I have. (OEM supplier for Corvette thermostats.)
According to the official 84~91 GM Dealer Parts Guide, the 86-89 C4s all used the same part number for the radiator #52453612. That being the case, I can tell you from actual experience with my 88, which should have the same stock radiator as the 87s, that if your 87 system is clean and workng correctly, a 180 thermo should not cause the fans to be on all the time at 35mph. I usually see 180~185 at 35~50 mph on days with ambient temps 90F and below. I've had a MAD aux fan switch that turns on my aux fan at 205 and off at 195 in my 88 for 5+ years and the aux fan is still not worn out. Other than when the A/C fan switch has kicked on the main fan, my main fan has ony come on one time in the past 6 years due to heat causing the coolant temp to reach 226F (GM Factory main fan start temp). The 86~89 radiator in conjunction with a 180 thermo can easily keep you near 180F if clean, unobstructed internally and externally, and the antifreeze/water coolant mix is correct.
Also, when the engine temp gets to 200 and his fans come on, the engine temp will have to go to 185 for the fans to go off and even above 35 mph, in the summer time the coolant temp will not go below 185 with stock radiator and water pump!!! So once the fans come on, they will stay on until the engine is shut off and it cools to below 185 F.
I'm not going to search the posts, but many CF members with 180 stats have posted that their coolant temps in summer temps stays well above 180 F!!!
I have a stock 88 with a clean, properly working, all stock cooling system, except as already noted for the aux fan switch which turns on the aux fan at 205 and off at 195, and the slightly higher ratio of water to antifreeze (60/40 mix of Prestone green). At sustained speeds above 35mph in the summer I usually see 182 plus or minus 3 degrees with both fans off. Before I thoroughly cleaned my radiator and replaced my worn out radiator cap, I would have agreed with your viewpoint. Now I know different. The C4 cooling system is pretty efficient when working at its optimum . I don't claim to see 182~185 at 35mph on a 105 degree summer day, but on a 90 degree day at 35mph my 88 which uses the same radiator and cooling system components as he 87, is usually under 185. Your mileage may vary.
For a street car, my personal opinion is that any switch that keeps the fans on until you get below 185 is doing too much fan work. I'd consider one that stops at 190 or 195.
