I mounted a BM tranny cooler in front of my AC condensor. It fit perfectly under there. I did use rubber hose to tie it into the existing lines. I think there might be something a bit better out there than just rubber hose. Maybe some of that fancy stuff that comes covered in SS braiding would be better.
One thing I can definately say it that my tempuratures definately did go up slightly, I assume due to the reduced air flow. However, once I switched the stocker radiator to a Dewitts hi performance radiator, I never see anything near those high temps again!
