84 vette missing problems
Old Jul 9, 2005 | 07:46 PM
svetter84's Avatar
svetter84
Default 84 vette missing problems
My 84 is missing a little but getting worse. When I accelerate it almost disappears, but when I am at a constant speed say around 40mph you can feel it bad. I have replaced the plugs, wires, dist cap & rotor cap. I looked at the injectors yesterday and they seem to be spraying fine. I am thinking its the distributor itself? Would appreciate anyones input! Thanks!
Old Jul 9, 2005 | 07:56 PM
CFI-EFI's Avatar
CFI-EFI
Try removing and plugging the vacuum line to the EGR and see if it goes away.
RACE ON!!!
Old Jul 9, 2005 | 08:32 PM
svetter84's Avatar
svetter84
Unplugged hose from EGR valve to EGR solenoid, no vac. Checked from injector to EGR solenoid plenty of vac. Guess EGR solenoid is bad?
Old Jul 9, 2005 | 08:55 PM
CFI-EFI's Avatar
CFI-EFI
NO! The ECM opens the solenoid and applies vacuum to the EGR when it is supposed to open. The EGR SHOULDN'T receive vacuum at idle. Now, can you simply plug one of the EGR vacuum lines (it doesn't matter which) and go for a ride??? Is the problem, better? Worse? Or the same?
RACE ON!!!
Old Jul 9, 2005 | 09:09 PM
svetter84's Avatar
svetter84
Plugged hose coming from EGR valve went for a ride, seems problem was the same or a little worse, actually hesitated once. I also pushed up on the egr valve diaphram from underneath while in idle and the rpms dropped. I appreciate the help CFI EFI, you have helped me before and You were right then when everyone else was telling different things! So again I appreciate it!
To 84 vette missing problems
