95 A4 problem
Old Jul 10, 2005 | 11:39 AM
95Purple's Avatar
95Purple
Default 95 A4 problem
My trans is in a 95 vette it’s an A4. The problem I have is that when I put it into 1st it starts out in 1st gear, as it should. But then it shifts into 2nd gear just as if it was in drive. It will then stay in 2nd until I shift to 3rd. So what’s up with that? I have looked all thru the programming and cannot find where it is messed up. If anyone has Tuner Cat I can Email you the .Bin file to look at.
Old Jul 10, 2005 | 12:22 PM
tjwong's Avatar
tjwong
At what speed does this upshift occur? I use TC if you like you can send me the file and I can take a look see.
tjwong@qwest.net
Old Jul 10, 2005 | 01:58 PM
95Purple's Avatar
95Purple
It does it at the same speed as when its in auto. I will Email you the file.
To 95 A4 problem
