Still can't re-set check engine light
Old Jul 10, 2005 | 03:33 PM
takovr's Avatar
takovr
Default Still can't re-set check engine light
Well I tried everything, pulled cb for ecm, disconected battery but still
have a check engine light when car is running. All I did was disconnect
the Maf so I could fix the rubber boot (it had a tear in it) what am I doing wrong ?
Old Jul 10, 2005 | 03:36 PM
JAKE's Avatar
JAKE
I'd first pull the stored SES code to see what the fault is. That should point you in the right direction.
Jake
Old Jul 10, 2005 | 03:47 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
definitely pull the codes!
If it is a MAF code, I had a similar problem recently. The electrical connector at the MAF was dirty and some of the female sockets had spread and were not making good contact.
Old Jul 10, 2005 | 04:10 PM
takovr's Avatar
takovr
Default i did spray some elictrical cleaner
I did spray some elictral cleaner in the maf connection, could it of leaked into the maf ?
Old Jul 10, 2005 | 04:15 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/SE...n%20Steady.pdf
Old Jul 10, 2005 | 07:13 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
YUP!!!!
I did the same thing! Electrical cleaner I used had some silicone in it and F'd everything up!
Get some 93% Isopropyl alcohol from drug strore and drown the connection in that!
That should do the trick
seeya
To Still can't re-set check engine light
