From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
A4 tranny pans
OK! I`ve had it , went to Goofy Lube to have the tranny oil changed, & was informed by the zit faced ( OH GOD, not another customer) kid behind the counter, that they no longer drop the pan to change the filters in auto trans any more. They just flush `em out with new fluid ( for $100.00 ). Its better that way says the kid. I said that for $100.00, you are going to run clean oil through a dirty filter?. He said that the flushing cleans out the filter. I said thats & left. My question is, who is using an aftermarket pan with the drain bolt, & what are your opinions. Do the cast aluminium ones seal well, do the chrome plated steel ones peel & rust?. I noticed that the price range for these things is from about $30.00, all the way up over $250.00. I was even thinking about drilling the stock pan,& putting one of those aftermarket drain assemblies from the HELP rack at Pep Boys, but they don`t look very reliable.
Ken
I have a B&M finned aluminum pan with drain. It is a thick casting that does not leak and is standard capacity. I tried their 3 quart extra cap. pan and it hung too low. It did not bring down the tranny temp.
Here is a little food for thought. My wife has a honda pilot. It holds a total of 8qts fluid, with 3 of those in the pan. According to the owners manual to change the fluid, which is recommended every 30,000 miles, drain the pan and refill, drive a short distance, repeat this 3 times. Then refill transmission. This process takes 12 qts to do.
Now if you do the math on it, this ends up getting most of the old fluid out of there.
St. Jude Donor '10
I just bought a polished, finned, aluminum pan off ebay. It includes the stainless bolts and a reusable rubber gasket. It also includes a drain plug. Quality and appearance seem very good considering it is an overseas item. My cost shipped was $50.
I'm not personally interested in a cast aluminum pan, but have been looking at Stef's for a fabbed pan. So far, I've not done a lot of research, but with billet rail and drain, but they are deeper than stock and I want stock depth due to the ride height of these cars.
I installed a drain plug in my stock pan about three years ago. Haven't had any problems with it. I bought it at my local auto parts store. It was made by B&M. Just make sure you put it in a location that won't interfere with the filter.
Ken, the drain plug in the help section is fine. The gasket is Mickey Mouse though. Throw away the nylon washer. Buy 2 fender washers with the same size hole. 1/2 inch , if memory serves. The fender washers are wide and will stiffen the plug. I put 1 on each side of the pan and use a small squirt of orange silicone(Ultra Copper) where the threads come thru. Never has leaks and is rock solid. I coat the small 7/16 drain bolt with a smear of liquid teflon. I charge $25 to furnish and install on the trannies I freshen. Most people think this is a deal. You can do it yourself for $7.
St. Jude Donor '10
Thanks Pete, I may just try that. Where would be the best place to drill the hole on the pan ( mine is an `87 if that makes a difference). You would think that GM would have included a 20cent drain plug in their trannys, but I remember back in `74-`75 when they tried to save a nickel, & for a year or two they quit putting drain plugs in radiators.
Ken, when you drop the pan you will see that the rear 1/2 is not good. Too much stuff in the way. I usually install it in the pass side front corner. Have a good look before you bang the hole.
