set valves, problems now
Setting the valves with the car off can be done, but I prefer to get them close with it off and then set them with the car running. With the car running you are nearly assured that all are pumped up equally with oil.
I've never had a problem or any ticking doing it this way but you guys are scaring me when it comes time to do mine.
Quickly making a 1/2 turn adjustment requires no correction. If you turn the nut down slowly, you should notice, nothing. If you turn it down quickly, you may cause the engine to stumble, because the valve isn't allowed to seat until the lifter self adjusts. Self adjusting, is the whole point of hydraulic lifters. IF you only turned it the intended 1/2 turn beyond zero lash, it makes no difference whether the adjustment was made slowly or quickly.
RACE ON!!!
You can also bend a pushrod tightening them too fast. I never do mine running but I know many like to and that's fine. I know I can get them just as accurate with the static method but then I've adjusted more valves on more types of engines than most people. It's just one of those things that the more you do it, the better feel you'll get for it.
Most of the problems you read of here on the forum, are from first timers who incorrectly identify the point of zero lash. Common instructions will have you twisting the push rod until you feel resistance to the twisting, and calling that zero lash. If the plunger spring isn't strong in some or all of the lifters, you (they) may not feel the resistance and continue tightening until the resistance is felt, when the plunger bottoms in the lifter.
I like to recommend jiggling the push rod up and down, as a more clear cut way of being sure of zero lash. The surest way of establishing zero lash, more accurately, is by adjusting the valve with the engine running. There is no mistaking when the clacking stops and zero lash is attained.
In short, if you have adjusted hydraulic lifters, successfully, in the past, you should have no problem with your Corvette. Just keep doing what has worked for you in the past.
RACE ON!!!
Intake Valve Adjustment: ENGINE OFF!
with #1 cylinder Intake Valve at full valve lift .... Adjust #6 Intake Valve
with #8 cylinder Intake Valve at full valve lift .... Adjust #5 Intake Valve
with #4 cylinder Intake Valve at full valve lift .... Adjust #7 Intake Valve
with #3 cylinder Intake Valve at full valve lift .... Adjust #2 Intake Valve
with #6 cylinder Intake Valve at full valve lift .... Adjust #1 Intake Valve
with #5 cylinder Intake Valve at full valve lift .... Adjust #8 Intake Valve
with #7 cylinder Intake Valve at full valve lift .... Adjust #4 Intake Valve
with #2 cylinder Intake Valve at full valve lift .... Adjust #3 Intake Valve
Exhaust Valve Adjustment: ENGINE OFF!
If you have noticed, this is the same procedure as the intake valves listed above, just that you are now adjusting the exhaust valves the same way.
with #1 cylinder Exhaust Valve at full valve lift .... Adjust #6 Exhaust Valve
with #8 cylinder Exhaust Valve at full valve lift .... Adjust #5 Exhaust Valve
with #4 cylinder Exhaust Valve at full valve lift .... Adjust #7 Exhaust Valve
with #3 cylinder Exhaust Valve at full valve lift .... Adjust #2 Exhaust Valve
with #6 cylinder Exhaust Valve at full valve lift .... Adjust #1 Exhaust Valve
with #5 cylinder Exhaust Valve at full valve lift .... Adjust #8 Exhaust Valve
with #7 cylinder Exhaust Valve at full valve lift .... Adjust #4 Exhaust Valve
with #2 cylinder Exhaust Valve at full valve lift .... Adjust #3 Exhaust Valve
Need an explanation?
Well, what you have here is "opposite" valves on the engine cycle. The small and big block Chevy engines use a firing order of 1-8-4-3-6-5-7-2. What you do is separate the order into the two sides of the firing order. These are "exact" opposites that put the opposing valve at the correct location for adjustment, meaning the back side (base circle, or heal) of the cam lobe.
1 - 6
8 - 5
4 - 7
3 - 2
If the lifter is anywhere other than on the heal of the cam where there is NO ramp contact you will have incorrect lash. The chart above makes sure you are on the backside of the cam lobe. When the cylinder is at TDC, this is not often the correct location to get the proper lash setting.
