Degreeing a +4 cam?
Old Jul 11, 2005 | 04:35 PM
ALLT4's Avatar
ALLT4
Default Degreeing a +4 cam?
If a cam is ground +4 degrees what should it look like when you degree it? Should I get it so it winds up +4 degrees or 0 degrees. I'm so confused about this, will the spec. card take the +4 degrees into consideration or should everything wind up looking like +4 degrees.
Old Jul 11, 2005 | 04:44 PM
STL94LT1's Avatar
STL94LT1
Maybe I'm just lucky. But, I've installed several cams, and always install them straight-up. I've never degreed a cam, and never had a camshaft related problem.
The 4* advance will give you a little more low end power.
CFI-EFI's Avatar
CFI-EFI
If the cam was ground advanced, all the points on the timing card will be the advanced numbers. You can verify that by looking at the lobe centers.
RACE ON!!!
Old Jul 11, 2005 | 05:05 PM
ALLT4's Avatar
ALLT4
So it's my decision if I wan't the cam straight up I add 4 degrees from the specified lobe center. 112 lobe center specified, changing it to 116 would negate the ground in advance right?
Comp Cams says they grind in 4 degrees for best street performance but I wonder if they really are trying to make up for eventual slop in the chain or a sloppy chain to begin with?
This is so confusing, I suppose if it's reading 112 center it should be fine.
Old Jul 11, 2005 | 07:14 PM
Red Tornado's Avatar
Red Tornado
take the ILCA (intake lobe center angle) + ELCA (exhaust lobe center angle) and divide the result by 2. The result should be the degree angle at which to install the cam.
for example:
ILCA = 108*
ELCA = 116*
108 + 116 = 124/2 = 112* degree the cam to.
Lingenfelter Performance told me this about a year ago.
Old Jul 11, 2005 | 08:53 PM
CFI-EFI's Avatar
CFI-EFI
for example:
ILCA = 108*
ELCA = 116*
Almost. What your calculation shows, is how to figure the lobe separation angle, and/or what angle to position the intake lobe centerline at, to install the cam "straight up". The lobe separation angle in this example is 112°. If this example cam is installed with the intake lobe centerline at 108° after TDC, as the cam card would show, the cam will be 4° advanced. If the cam were to be installed with the intake (and by default, the exhaust, too) with the intake lobe at 112°, the cam would be installed, "straight up". Simple, eh?
RACE ON!!!
To Degreeing a +4 cam?
