MODs made, Now 88 Corvette won't start
Old Jul 11, 2005 | 08:13 PM
Supernatural's Avatar
Supernatural
Default MODs made, Now 88 Corvette won't start
I made the following changes and now the car won't start. I took apart everything down to the lower intake. I removed all the EGR equipment and installed the block off plates. I tucked the old connectors out of the way. I installed an AFPR, 1997 LT1 injectors. I removed the 9th injector and installed the plug at the end of the fuel rail and in the side of the intake runner (I got both from S&P) ans tucked away the old connector. I smoothed out the inner casting of the runners and inside the plenum. Lastly I installed the 1" inch TB spacer (also from S&P). I connected everything back up and the car just turns over and over, but won't start. I know I am getting fuel to the fuel rails because I installed a fuel pressure gauge to set the new fuel psi. The only thing I can think of is the 9th injector being the problem. I have heard of others taking it off and not having a problem. Do I need a new chip that deletes the Cold Start Ijector or what. Please Help!!
Thanks,
John
River City Corvette
Old Jul 11, 2005 | 10:14 PM
John A. Marker's Avatar
John A. Marker
You are getting fuel pressure, but are you getting spark? Pull a plug wire and throw a screw driver in the plug boot and lay it on the engine so that the screw driver's handle is holding the metal shaft 1/8 to 1/4 inch from a metal surface. Then turn over the car and see if you get a spark. If not, check your wires. GOOD LUCk
Old Jul 11, 2005 | 10:25 PM
RWDsmoke's Avatar
RWDsmoke
To check for spark I hook up a timing light and point it at the windshield so I can see it from the drivers seat. I also use an injector tester that will tell me if the injectors are pulsing. I deleted the cold start on my 86 because I have an lt4 intake. I programed the chip with the 89 bin file that doesn't use cold start. Should be able to start it without in warm weather.
Old Jul 11, 2005 | 10:27 PM
sniperdiver37's Avatar
sniperdiver37
Yes you need a new chip burned
you have changed what the ECM thinks it should do. Now you need to tell it what to do with the Mods.
Old Jul 11, 2005 | 10:33 PM
shadetreeperf's Avatar
shadetreeperf
Since you have disabled the 9th injector, you need to have a new chip that adds in the extra fuel that the other injector was adding.
I did this same thing on a '88 GTA and it won't start with the stock programming, I put in a chip with a bin file from a '89 and it fired right up. Unless you've left something unplugged, this should be all that is keeping it from starting. You could, just to check, put the extra injector back in and see if the car starts, then you would know for sure if that was the problem.
KC
Old Jul 11, 2005 | 10:37 PM
sniperdiver37
well said
Old Jul 12, 2005 | 08:20 AM
WNDOPDLR's Avatar
WNDOPDLR
I disagree with those that think you need a new chip. I installed a Mini Ram on my 88 eliminating the 9th injector. The car needs to be cranked a few more times, but starts and runs fine. I have NOT installed a new chip nor had my chip re-programmed.
Old Jul 12, 2005 | 08:40 AM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
Occasionally my 88 without the cold start injector is hard to start and will flood. Opening the throttle a little bit while cranking will usually do the trick (think starting a carbed car). If you think it's flooded, try putting the gas pedal to the floor while you're cranking, just don't hold it there once it starts
Old Jul 12, 2005 | 08:41 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I bet something may not be plugged in properly. Fuel pressure doesn't mean much if the injectors aren't firing. Use a noid light or a test light and check to see if the injectors are firing. One side of the injectors is always hot with key on and the other side gets the ground from the ECM. Once you have tested for spark and injector firing you'll be closer to finding the answer. Here is some info from my 86 manual.
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Jul 12, 2005 | 10:13 AM
Aardwolf's Avatar
Aardwolf
My '88 starts fine without the CSI plugged in so it's not that. You could try starting fluid if you think it's to lean to start. I think the PCV line goes into the intake, to use for the spray? With the AFPR you can tune the larger injectors, so it's not that. What pressure is there when the car cranks? Did you take apart the distributor at all?
Old Jul 12, 2005 | 07:26 PM
Supernatural
I re-charged the car and tried the idea of the starter fluid in the PVC port. It never started, but a couple of times I got a small grumble when I let off the ignition key. I rechecked all of my electrical connections. The Only 3 still disconnected is the one to the EGR temp sensor at the back passenger side of the manifold, the main EGR sensor at the water neck at the front of the maifold and the 9th injectors connector. All of the other connectors are tight. I never took apart or disconnected the distributor, I just had the NEG side disconnected for safety. She still won't start I'm stumped.
Old Jul 13, 2005 | 04:38 PM
Supernatural
Bump- Any other thoughts?
Old Jul 13, 2005 | 05:30 PM
brookman's Avatar
brookman
I just did this job all the way down to the deck.
engine top end tear down
Did you remember the connector under the manifold?
Did you remember the brake booster connection? That makes a huge vacuum leak. (ask me how I know)
Did you verify that you had spark?
You said you added the one inch spacer. Did you reposition the throttle cable mount? This is a long shot but you know if you are pressing on the throttle (which is what the ecm would sense if the throttle cable wasnt lengthened) the ECM will assume you are telling it that the engine is flooded and not provide any fuel.
To MODs made, Now 88 Corvette won't start
