85 fuel problems
So do I. And given that you have solid fuel pressure, I'm questioning whether this is fuel related at all.
Spray some ether (starting fluid) down the throttle body and see if she lights off. If not, let's start looking at either an ignition or a timing issue.
Given that the noid light is lighting up, the injectors should be firing. Have you pulled the plugs to see if they're wet?
Has this vehicle been sitting for an extended period of time, or did the no start condition appear suddenly? During extended sitting periods, gasoline does deteriorate, and it could simply be spoiled fuel or water in the fuel. If it suddenly quit running, I would start looking at an ignition or timing issue.
Do you have any codes stored in the ECM?
Try the starter fluid and see if it fires and runs....and then we can go from there.
They really only need 4 things to run.....the correct fuel and air mixture, sufficient compression, correct timing (valve and ignition), and a sufficiently strong spark to light the mixture. Everything else is icing on the cake.
Time to isolate which factor is amiss.
