L98 vs.LT1,how much faster when modified?
I was just wondering how much faster my near stock auto 94 feels out on the highway,(only mods are cats delete,tuneup,and cut lid right now,)compared to my 90 conv,which basically had every bolt on without removing the valve covers.Granted,my 90 was a high 12 second car,but it still doesnt feel like it has this pull out on the highway,but probably made as much rearwheel horsepower.we know LT1's(mid 13's) are about .5 quicker stock than L98's,(low 14's)and have about 45 more rearwheel horsepower,but how much if/does the gap close when both are modified?I've seen mid-low 12's for LT1's when modded,compared to high-mid 12's for L98's.I mean any bolt on that doesnt touch oil,while keeping the longtube runner setup.list of mods,dyno #'s and 1/4 mile times appreciated
Here are my thoughts
L98 makes better low end power much more selection of performance parts and can be made to be stupid fast if it is SB GM you can probably make it work with this combo and even the intakes.
LT1 Better power up high and responds to mods well but limited in parts selection, heads you have 4 choices GM AFR TF and edlebrock Blocks one GM
I would have had to get into the motor to take him.
has he ever had his car dynoe'd?with those traps,its got to be around 280.Thats what also I was curious about,is that around what the limit of power is for a N/A L98 with LTR's,and a little over 300 for LT1's?
Your L98 with bolt ons might make a ton of torque and run 12's and still not feel as fast on the highway as the LT1 simply because of the LT1's ability to turn higher revs. It's the classic HP vs Torque battle, which ultimately always amused me because they are the same thing. HP depends soley on torque and RPM, so the real argument is LOW RPM torque vs HIGH RPM torque. Your L98 has more low end, your LT1 has more upper end. As such in the higher revs the LT1 is gonna feel quicker, which the TPI is going to feel faster stoplight to stoplight. Your observations are perfectly normal.
A good example is my friend's car. He has a '87 Iroc with a 350 SBC, carb, Hot Cam, v-6 trans and 3.73 gears. He swears up and down that his car feels faster than mine, despite the fact that I can run 12.7's and he runs 14.3's. His gearing makes his car feel really fast, but he runs out of RPM really quickly and it fades. So yeah he's right. He puts more torque to the ground than I do from a dead stop until the top of first gear. The problem is once he has to shift, I'm still in 1st gear where I am then effecitvely putting more power to the ground. Likewise I'm halfway through second while he's shifting into third. Plain and simple I walk away from him like he's sitting still although this car "feels" faster.
Its all about how you drive the car and what you perceive as fast. As far as the two engines go, one is really no better than the other as far as HP capacity belongs. Both can make insane power if you've got enough money to spend. The SBC has the advantage of having a larger variety of aftermarket parts, but so long as you've got money either one can make killer power.
with everything you said nathan.It all goes back to intake tract length of the 2 engines.TPI's are about 21 inches which creates a resonance effect when the air enters the cylinder,which creates more pressure,compared to the LT1's 3 inches which doesnt take advantage of any resonance.I do miss my L98's off the line power,I could basically "tap"the gas on some of the ones Iv'e had and could light the tires(especially my GTA).They ate tires up faster though!I would like to have that "feel"back,without losing this topend.and I'm guessing with 3.73's,and the right converter I will,but most of the driving I do right now,is highway,so I'm not sure about the gears.That should be a main point when others are looking for a C4,the type of driving you will be doing.If you mainly do street driving,stick with the L98,you wont miss(or need to pay for)the LT1's extra power.If you travel alot on the highway,and like that passing power,go for the LT1.Another comparo I remember was with my 90 GTA,had all the SLP boltons(intake,exhaust,converter,gears)M y friend had traded had just got a 02 ZO6,when I took it for a test drive,I wasnt impressed with the power on the street compared to my GTA,which probably had 100hp less.I was like,"this is the mighty 405hp ZO6"
however,from a roll,or out on the highway,that thing pulled like a freight train,
and although we never raced,I'm sure I wouldnt be able to count on 1 hand how many car lenghts I would have been behind.
BTW, he runs skinnies up front, slicks out back and pulls 1.7x short times. I'm not sure but think that MrMojo is running skinnies on his A4 Vette too.
I think both the LT1 and the L98 can be modded for close to 400chp, though the L98 requires LT runners & base to breath better up top.
If you do the SR or MR intake then it's really no longer a L98 is it. Then the runner length is closer to that of a LS1 than a LT1.
Larry
like I said,its really hard for a N/A 350 L98 to be streetable and make over 400hp.not saying it cant be done,but I dont know of to many out there,that have good idle/driveability.HP=torque x rpm/5252.The long runners wont allow the airflow to make the RPM to produce the power.its easier if you change to a SR,or MR,or go with bigger cubes,like 383 or 406.
L98<LT1<LS1<LS6<LS2<LS7 in stock form. Start modifying them though, and well I still have to bet money on the LS7, but really it all depends on how much money you want to spend.
I dont know what problem your friend's Z06 had, but I seriously doubt that your SLP modified F-body was faster than a typical Z06 on the street. I have both an 02 Z06 and an 95 LT1 C4 and have driven many L98 F-bodies and Vettes over the years and neither the LT1 nor the L98 cars compare in thrust at any speed to the Z06. The first 25 feet or so in first gear may feel slightly more responsive in an L98 and perhaps an LT1, mainly because the Z06 is spinning (more likely hopping) its rear tires, but after that, its good bye. My car is stock (plus no DRs) and runs severely traction limited 12.3's at 117 at greasy Englishtown Raceway Park. My Z06 can do traction limited 0-60s (measured with a G-Tech) between 4.18-4.34 sec in 90 degree weather on the street. On the same street, in the same heat, the best my LT1 could do is a 5.27 and most runs are between 5.35 and 5.50.
Going back to the original inquiry of this thread, IMO, the L98 would be my choice to modify. Although the LT1/LT4 can be easily modified to make very substantial power, the options for doing so are fairly limited. If you check this site, you will see that most people modify their LT1s in more or less the same manner, ported or non-ported LT1/LT4 heads, hot cam or the like, etc. In every case, you are limited in creativity to the OEM intake system of the LT1/LT4 and the LT1/LT4 heads (Yeah I know Edlebrock is now making heads for these engines). You can get much more creative modifiying the L98 engine since the L98 specific TPI system and heads can be replaced with any number of various aftermarket carb, intake manifold, head, and cam combinations for Gen I SBCs. It is mainly the L98-specific TPI system that make these engines feel wheezy on the highway. I've driven a number of modified 350 ci SBCs that were fairly civilized, could wind to 7200-7500 rpm and made great power doing so. Although these engines were a little light on torque below 3000 rpm, they had gearing that allowed the cars to get quickly into the power band. The pull through the gears is extremely satisfying and the sound of a SBC with a carb at 7000+ rpm is unlike anything I have ever experienced in a fuel injected L98 or LT1 variant. Of course, if your not willing to scrap the L98 TPI system, then I would go with the LT1/LT4. At least an LT1/LT4 wont embarass itself from a roll-on on the highway before or after being modified, as is apparently the case (according to this thread) with modified L98s.
