Be Cool radiator, not impressed!
Old Aug 26, 2005 | 11:38 PM
  #61
kpforce1's Avatar
kpforce1
Originally Posted by CentralCoaster
Moving the water faster WILL help. But, what CFI said is very true, and often overlooked. It's just not that simple. To see why it helps, you'll have to understand LMTD (log mean temperature difference). Joby touches on this when he talks about the temperature on the cold side of the radiator.
Oh i understood it, i just got off topic and siad how much I hated my thermo class in college. lol
Old Aug 27, 2005 | 12:16 AM
  #62
cv67's Avatar
cv67
St. Jude Donor '05
Scott 89- Pull the radiator shroud off and clean out between the rad. and condensor, you should see a big difference. Pulling the main fan off and waterblasting the fins of the radiator towards the front of the car will also help. Keep spraying, there's tons of tiny debris that really get stuck in those fins. Enjoy the vette
Old Aug 28, 2005 | 01:06 PM
  #63
SJW's Avatar
SJW
Originally Posted by CFI-EFI
Too bad this isn't.
If "Moving coolant through the radiator very slowly will allow each molecule of liquid that passes through the core to shed more heat", then conversely, Moving coolant through the engine very slowly will allow each molecule of liquid that passes through the block and heads to absorb more heat.
Remember, too, that part of the ability of the coolant to absorb or reject heat is dependent on the difference in temps. If the coolant gets cooler by traveling more slowly through the radiator, then it will be able to absorb more heat from the engine, first because it was cooler going in and second because it was in there longer.
If the time in the radiator is increased, so will the time in the engine.
RACE ON!!!
Ah, this'll remind me to not make such a post hastily, and when I'm overtired.
Thanks for the correction, CFI-EFI
Be well,
SJW
