obd II emmissions ?
Old Jul 13, 2005 | 01:44 PM
redbullapril23's Avatar
redbullapril23
Default obd II emmissions ?
1996 lt1 auto.
no cats mufflers or resanator.
02 stims
all stock internals
LT hooker header 2151
ok
I disconnected my battery and then went to the emmissions place to see if i threw any codes which i did. this was free btw.
ok obviously it didnt go though a complete obd 2 cycle and came up as not ready.
BUT
it said EGR/ AIR not hooked up.
I took that out when i first did my headers because there were no smog provisions on my headers. can I just hook that stuff back in and then it wont throw that code?
what should I do
I live in atlanta georgia
your friend
Sean
Old Jul 13, 2005 | 02:44 PM
bogus's Avatar
bogus
And you honestly expect to pass an ODBII emissions test without cats?
I have so little sympathy for you right now, it ain't even funny. You avoid some minor emissions controls, that do more to keep your engine running smoothly and are now trying to figure out how to be reasonably legal. Too late, bud.
You need to get headers, or install manifolds, that are smog legal, then reinstall all the EGR hardware. That will get your EGR back on track.
This is an abstract, but have you ever considered installing cats?
Jeez.
I am done here.
Old Jul 13, 2005 | 03:47 PM
99svrcpe's Avatar
99svrcpe
Shame on you for aggravating the Emissions Gods.
you should be able to weld in bungs for the air pipes however if emissions testing is required in your area then you won't pass without the cats.
also based on your setup, you may have a bigger problem with noise pollution.
Old Jul 13, 2005 | 06:03 PM
redbullapril23
well as soon as my random tech cats come in...jeez!
I just need to get emmissions so i can drive the dang thing.
but is there any way to get around the EGR or ghetto rig it for the tests?
I mean all it does is force extra air so that cats burn up all the pollutants but its not necessary especially if you have your car tuned right like myself.
thanks alot your friend
Sean
Old Jul 13, 2005 | 06:07 PM
redbullapril23
can some one please help with out blowin a fuse and or being sarcastic.
I really need help.
thank you
Old Jul 13, 2005 | 06:10 PM
bogus's Avatar
bogus
Dear God, Sean... you have no clue what these components do. It's blatently obvious.
What "emissions test" are you going to pass if you have no cats and no EGR?
Not one I am aware of.
EGR = Exhaust Gas Recirculation. It has NOTHING to do with forcing air into the cats... that's another function. It has everything to do with bringing in exhaust gases and using them to lower combustion temperatures, which result in lowering NOX. On older motors, that's the only way to effectively lower NOX emissions. Chiefly, because NOX is not burned off by the cats.
You need to take that car to someone who knows what they are doing. You sure as hell don't.
Old Jul 13, 2005 | 06:15 PM
Zix's Avatar
Zix
I know of one...and it's called the OBDII emissions test! How do I know? Because I have no cats, no O2 sims, and no EGR/AIR (but the LT4 had an EGR blockoff anyway), and I pass with flying colors eveytime. There is no emissions test, just a computer test to make sure there are no codes and the systems are working. Well, the computer can easily be reprogrammed to say whatever you want it to.
Old Jul 13, 2005 | 06:24 PM
bogus's Avatar
bogus
I stand corrected... which makes that test utterly useless in the grand scheme of things.
Old Jul 13, 2005 | 07:01 PM
redbullapril23
Not one I am aware of. You need to take that car to someone who knows what they are doing. You sure as hell don't.
agian OBD II unless they require a visual like cali then i should pass.
I dont know if its necessary or not i have a block off plate on the EGR air. agian its not necessary. I went to the emissions place and all that it read was that car was not ready for emmissions because i hadnt driven it enough and that the egr air was not hooked up.
I mean i didnt know if that ment if I could still have it pass.
thats all i want to know.
Old Jul 13, 2005 | 07:32 PM
Zix's Avatar
Zix
You will need to do something about the EGR or else it will not pass
Old Jul 13, 2005 | 07:36 PM
CFI-EFI's Avatar
CFI-EFI
No. You couldn't pass because the car wasn't ready.
Bogus hit the nail on the head when he said, "Dear God, Sean... you have no clue what these components do. It's blatently obvious.". There is no such thing as "egr air". There is the EGR system and the AIR system. How can you modify an engine or know what to expect from making changes, if you don't even know what you are changing or what it does? I think the "metalurgest" (sic) needs a little more "edumaction" on how these things work. Have you been to www.helminc.com ?
RACE ON!!!
Old Jul 13, 2005 | 07:43 PM
redbullapril23
knock me all u want my car is still faster
look man all they did was hook it up they didnt even run it
thats all it said
i didnt get it tested
the emissions guy did that to help me out and save me $ as i asked him to do that.
yes i understand the EGR/air are different
thats y in my origional post i used a slash and i missed it in a later post.
I am done with you guys
agian CFI EIF u have a corss fire
bogus u dont have an obd I lt1 and u even sauid u were wrong.
I mean im glad u guys have such expirence with my car
Old Jul 13, 2005 | 08:23 PM
CFI-EFI's Avatar
CFI-EFI
Than what? Before? What did it used to run and what does it run now?
the emissions guy did that to help me out and save me $ as i asked him to do that.:
It looks the emissions guy wasted his time on you. He did you the favor but it means nothing to you.
I think Bogus was talked into admitting he was wrong, because he isn't sure. I'm not sure, either, but I find it hard to believe it is that easy to defeat. Hell! If it's that simple even YOU may be able to do it. I may not have any experience working on your car, but I know more about HOW it works than you do. Double that for Bogus.
RACE ON!!!
Old Jul 13, 2005 | 08:42 PM
96GS#007's Avatar
96GS#007
To pass the visual you need to reinstall the components.
To pass the OBD II test, you need to understand what your states' requirements are. To my knowledge, all states will flunk an OBD II car that has the Service Engine Soon (SES) light illuminated. The illuminated SES can be addressed via PCM tuning. However, just because the tuning turns off the light doesn't mean it sets the associated drive cycle flags to "Pass". None the less, some states will pass an OBD II car with only a partial drive cycle completed/passed. Others are more strict. Drive cycle flags/status can be observed using a scan tool or software like AutoTap.
FWIW, in the '96s the AIR system has absolutely no impact on engine performance since the pump is electric. You save a couple pounds of weight and that's about it. Likewise with the EGR. As I recall the
EGR is only commanded open during part throttle and has no affect on WOT.
Old Jul 13, 2005 | 08:43 PM
bogus's Avatar
bogus
I am with CFI-EFI... I know more about how your car works then you do, as does CFI-EFI.
Now, I have ODBI on my LT1... you have ODBII on your LT1? Whatever...
Some states have different tests...some only check the function. It's an attempt to speed up the emissions testing. Zix reminded me of this when he made his post. Delaware does the same thing.
Which means, if you are able to fake out the computer, you can pass the ODBII test.
Good luck. You don't know enough about how the systems work, let alone how to modify the damned computer.
Give it up.
Old Jul 13, 2005 | 08:50 PM
redbullapril23
thanks guys this really helps. and yes even u bogus because you acctually said somthing helpful.
I bet i could get LT1 edit and have them to turn off the SES. correct?
any idea where i can find info on what georgia tests for as in partial or full all out.. i am guessin its partial as alot of the c5 guys around here have no cats, 02 stims, headers, etc.. and have no problems
I mean the reason for disconnecting the battery was to clear the codes and drive to see if they came back on... which it did so thats what im working with now!
that sounds good.
Sean
Old Jul 13, 2005 | 09:26 PM
FELNGR8's Avatar
FELNGR8
that sounds good.
Sean
After clearing the codes you need to drive the car some minimum of miles, 50 miles I think, before it will report ready for emissions check. This is to assure the car was not reset just down the block before entering the emissions station.
The AIR and EGR checks can be programmed out with LT1 edit. It was turned off in my last tune although I haven't yet yanked the plumbing. EGR through the pipe from the exhaust is redundant with the LT4 (or with a Hotcam) as valve overlap does the job to satisfy the NOx requirement.
To obd II emmissions ?
Old Jul 13, 2005 | 09:55 PM
redbullapril23
sweet sounds good I also just figured out that here in Ga, they just plug into the comp scan and then hand you a certificate.
which is what i was originally told I just had alot of ppl sayin it wasnt true.
thanks alot guys.
yea you have to complete a full OBDII drive cycle which I have the instructions for.
your friend
Sean
Old Jul 13, 2005 | 10:06 PM
Perfusion's Avatar
Perfusion
My friend Sean,
To quote Will Smith from iRobot, "Some how 'I told ya' so'...just doesn't cut it." Most won't remember, but I clearly recall a thread from many months ago when you were passing bad advice to newbies who were none-the-wiser about passing emmissions without cats. I even stepped up and challenged you at the time on your statements, and all I got was a song and dance about GA this, GA that...OBDII...blah, blah, blah.
Now look who can't pass!!!!!
In the future, engage brain before putting mouth in gear.
Your friend,
Aaron
Old Jul 13, 2005 | 10:15 PM
redbullapril23
look man i havent even gotten tested... so huh?
I was just didnt know how to get rid of that code to pass.
I am gettin lt1 edit next week and then going to emissions
i will pass no problems.
with 02 stims an LT1 edit you have no prob.
end of discussion!
shows how many friends I got
life is to short to be mad
your friend
Sean
