obd II emmissions ?
O2 sensors
O2 sensor heater circuits
AIR systems
EVAP systems
Catalysts systems
Just having o2 sims in the rear sensor positions won't cure the problem in most cases. The PCM may not set a code but I can almost gurantee you that the IM240 ready status for that system won't be ready.
I am pretty sure that ( well according to locals here) that as long as no codes are thrown i should be good.....
well they all tell me you pull in the hook it up scan the comp for a couple mins and then give you a certificate.
so youre saying with LT1 edit. and editing out the flags I should be good. Im almost positive that its what people do around here.
I wonder how I could find that out for certian... maybe go talk to mr emissions agian.
TJ thanks alot!!!!
thanks your friend
Sean
I rest my case. Flame On.
And as to our good friend here who started the thread, red, you are so misdirected and relatively uneducated, that it's enough to make others see "red". In your all out quest for power on the street vs. putting it on the track-only where a polluting car might (I say, Might) be, you don't listen, and worse, you don't understand what's being said to you here.
And it comes to you from people who either know more than you, or have more experience than you do.
Too bad! For us, because we gotta breathe your mistakes, and for you in so many ways. Whatever you do, you may pass Georgia emissions. But you won't, and don't pass the more important test.
Wise up, there's still time and hope.
Your friend,
Aaron
I see that he is, "Your friend". I remember when THAT originated. I pretty much forced him into continuing that sign off. Anyone can be his friend, if he thinks he can wheedle something out of you. Like a typical flim flam man.
Every time he is wrong, which is often (he doesn't know what he's doing), he denounces his critics and resorts to name calling, and off the subject insults. It will be interesting to see how this smog test business works out, if he'll admit it. In the past, when asking about modifications, he assured everyone that he didn't have to worry about smog tests. Intimating that his area didn't have them. Or at the minimum, expressing that he knew the way around them. In either case, here he is again, proving himself wrong. Hopeless!
RACE ON!!!
So very well put. I could almost cry. I am so proud right now... wow.
For all the power that modern emission controls rob (no more then 10hp) for their benefit... seems like a no brainer to me.
RACE ON!!!
It's what I was saying above...
this is simply not what thats about
any ways.
good bye
thanks for the help
my local palls helped as well.
so thanks for the constructive criticism
it does help.
your friend
Sean
Acctually
where I got my line hey your friend Sean
is from a very important mentor to me.
Mr. Andrew W.K.
ive had the pleasure of meeting him 2-3 times and I see all his concerts here in atlanta all 6 of them.
He has written me letters and signed shirts all with words of advice. and he always ends them by sayin your friend
Andrew W.K.
just by meeting me for a small fraction of time. he is a great guy and is always looking to help people and be friends with everyone.
so thats where I am coming from. hes a great guy who aspires to make everyone feel good and hopefully have an impact on us kids these days for the better, which I assure you he does.
for what thats worth there you go
end of convo
when I say your friend I say that as in what can I do for you?
I am humble and I always try to help people out to the best of my knowledge and if they need help.
I am not the bad guy you make me out to be, honestly.
I have a word for people like you: hypocrite.
any ways.
RACE ON!!!
good bye
thanks for the help
my local palls helped as well." Quote from your friend, Sean. or whatever...
I gues I must be outa da loop (dee loop
)'cause I have NO IDEA who Andrew WK is. I maybe should care????/
Any ways (as some might say and speellll it), that quote above just about sez it all for me:
"my local palls..." is that like local "pall" bearers?? hmmmmm. Deadly serious, our friend Sean is here. Hmmm. Freud, Freud? Wherefor art thou???
Environmentalist? Gawd, The Sierra, Wilderness and Nature Conservancy types must RUN when they see or hear your name, I'm sure.
Be well, "Pall" Sean, and do try to breathe in as much of your "environmentalist" exhaust air that's non-polluting as you can. It makes it all better for us'n.
Sean providing inaccurate information to noobs as if he was an expert?
That would never happen.
[/sarcasm]
