Can someone explain alky injection? (89A4)
Old Jul 13, 2005 | 09:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Can someone explain alky injection? (89A4)
Non supercharged. What are the benefits and exactly how would it work on an L98. Could this be plumbed in through a Holley throttleobdy(setup for Nos)?
Old Jul 14, 2005 | 08:28 AM
ztrips's Avatar
ztrips
Non-supercharged? Hmm.. I would assume the benefits would be the same as on a FI car, just not as great. You could run increased timing and higher compression without detonation.
Old Jul 15, 2005 | 11:38 PM
Mo_Bandy's Avatar
Mo_Bandy
I would agree, probably the only benefit is it will somewhat cool your intake charge, but if you are going to run NOS that is the whole principle of NOS.
Unleess you had an RV going up long mountain grdes in very hot temps, I seriously doubt it would be of much benefit with a N/A engine...
"MY 46 dollars"...
Mo
Old Jul 16, 2005 | 12:13 AM
qwiketz's Avatar
qwiketz
the only situation I've heard of people using alky injection was with high compression and pump gas. They would have a switch to flip on the system to gain the octane effects once the throttle was depressed a bit so that the octane effects of the h20 alky mix would kick in when the motor needed it. Guys also do something similar when using nitrous.
To Can someone explain alky injection? (89A4)
