O2 Sensor Replacement
Old Jul 14, 2005 | 01:44 AM
PierEagle's Avatar
PierEagle
Default O2 Sensor Replacement
Getting ready to replace O2 sensor on '87 and I see conflicting responses on other threads. Is it easier to do, hot or cold? I know the new sensor is pretty solid but has anyone broken one off while removing, or damaged the e-pipe?
Thanks.
Old Jul 14, 2005 | 09:58 AM
rick lambert's Avatar
rick lambert
I had NO problem replacing the 02 on my 87 cold.
Old Jul 14, 2005 | 09:59 AM
conv90's Avatar
conv90
the same with my 90.
-Beppe-
Old Jul 15, 2005 | 01:02 AM
PierEagle's Avatar
PierEagle
RICK
conv90
Thanks for the response. Gonna do it this weekend.
Old Jul 15, 2005 | 04:19 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Thanks.
If the sensor were properly installed, it should have received a coat of "neva seize" on the threads. When you install the new one do not get the antiseize anywhere near the element.
Also, I would recommend investing a few bucks in the socket that is made for removing/replacing these things
seeya
Old Jul 15, 2005 | 04:24 PM
Wayne88's Avatar
Wayne88
here you go buddy.
This is the instructions from my '88 Helms GM shop manual.
I'm sure its the same for an '87.
Note that they say to disconnect the negative battery cable first.
Old Jul 16, 2005 | 01:02 AM
PierEagle's Avatar
PierEagle
JACK and WAYNE
Thanks for the additional info.
To O2 Sensor Replacement
