Weird stalling problem
Old Jul 14, 2005 | 02:42 PM
Beladona_13's Avatar
Beladona_13
4th Gear
Default Weird stalling problem
I have a 90 'vette (not the zr1) that will run fine until it gets warm. Then it begins stalling. Will start and immediately stall. If I unplug "number one" fuel injector the car will continue to run with a slight miss. If I unplug any other injector, the car still dies. I have recently replaced Fuel pump, filter, egr valve, plugs, wires, cap, rotor, coil, and ignition module. Should I replace this fuel injector? Help!
Old Jul 14, 2005 | 03:40 PM
Chest-nut's Avatar
Chest-nut
I had exact same problem with my '89. Replaced all injectors. Problem solved. You will definitely want to replace all injectors at same time. Originals suck. Your others will do the same thing in time. Will save you from reoeating this job in the near future. You can get new injectors on E-Bay for arpund $200.---Mike
Old Jul 14, 2005 | 05:45 PM
Beladona_13
4th Gear
Due to limited funds after other repairs I changed only the suspect injector. Problem solved. Checked it with an ohm meter, 6.5 ohms. I believe it is supposed to be around 13 ohms. Thanks for the tip. I'll replace the rest next time around!
To Weird stalling problem
