ATF-interesting if its true
Old Jul 15, 2005 | 09:11 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Default ATF-interesting if its true
I was at a shop the other day, & I asked a question about power steering fluid (which was answered in another thread), & we got to talking about ATF for the C4`s. I asked the difference between DexronIII, & Mercon V, & was told by the mechanics there that there would be no problem using the Mercon in my 700r4. They said that GM spec. fluid makes the trans shift smooth, & soft, whereas if I filled the trans with Mercon, it would more or less bang into gear, sort of like having a poor mans shift kit. They also went on to state that B&M racing tranny fluid is nothing more than Mercon fluid dyed purple. They said changing to the Mercon fluid would not hurt the GM trannys at all. Like I said---Interesting if true
Old Jul 15, 2005 | 09:42 AM
vader86's Avatar
vader86
Its your tranny, I wouldnt put anything in a 700 that wasnt spec'd for it. Too expensive a fix.
Old Jul 15, 2005 | 09:43 AM
mseven's Avatar
mseven
I was under the impression that the b&m trick shift was ford fluid.
Old Jul 15, 2005 | 10:14 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Mercon is a Ford-spec fluid.
Larry
code5coupe
Old Jul 15, 2005 | 10:52 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Larry
code5coupe
Yep, when I bracket raced for years, this was a commonly discussed trick to get a TH 350/400 to shift harder. I always preferred to have the transmissions built to do what I wanted.
Old Jul 17, 2005 | 06:31 PM
Bartmantwo's Avatar
Bartmantwo
Mercon I is pretty much the same a Dextron. Type F is what the shop meant. B&M fluid make it shift even firmer. It has more than twice the friction increase compared to type F.
You would probable be bet off using Dextron III since it has better lubrication properties then earlier Dextron and Type F.
Also Mercon V will make your make shift even softer since it was designed to fix ford shifting problem.
Old Jul 17, 2005 | 06:34 PM
rws.1's Avatar
rws.1
beleive the diferences between the various types of transmission fluid are related to viscosity and slipperiness ( friction)
To ATF-interesting if its true
