I am attempting to replace the rear main seal on the zf tranny. I have the c-beam bolts off and it is pushed over to the right side, but still on. I have also removed the bolts and 2 metal straps holding the driveshaft onto the differential. The haynes manual says to just slide the driveshaft forward to unseat the u-joint and then back off of the tranny. The driveshaft will not slide at all, forward or backward. I can pry it forward and the u-joint is unseated from the differential (not rusted on), but it will not go far enough forward to remove. How are you suppose to remove the driveshaft, or what I am doing wrong?
Thanks. 96 LT4.
Thanks. 96 LT4.
It sounds like you are doing everything correctly. You can try prying harder to push the slip yoke further into the trans to allow the u joint to clear the pinion yoke. You shouldn't have to, but you may gain enough extra clearance by removing the caps from the ends of the u joint. If you do this, take care bot to lose any of the needles from inside the caps.
I really struggled removing mine to! I eventually used a pry bar and rubber mallet to move it far enough out of the way to pull the Ujoints - then dropped the beam and the driveshaft together. (you will need to be able to turn the wheels 1/2 turn to get access to all the Ujoint bolts.
Carl Johansson
Thanks. 96 LT4.
Has the rear of the transmission dropped with the removal of the C-beam? If so try lifting it up to gain some clearance if that doesn't work try dropping it a little. It will come out!!
RACE ON!!!
That's what I had to do on mine -- take the rear U-joint caps off the trunnion.
