code 15- engine coolant temp sensor
Old Jul 17, 2005 | 07:22 PM
qwiketz's Avatar
qwiketz
Default code 15- engine coolant temp sensor
Well I thought I would have gotten rid of the datamaster dtc err....
I previously broke the coolant sensor when trying to do a pulley change. I replaced it and now it registers but still gives me a dtc error, citing #15. I replaced it with a borg warner sensor from pep boys. The coolant temps look to be correct(on the datamaster screen) yet it's still giving me the error code. What gives?
Old Jul 17, 2005 | 07:32 PM
STL94LT1's Avatar
STL94LT1
Try resetting the code, and see if it comes back.
Old Jul 17, 2005 | 07:36 PM
SunCr's Avatar
SunCr
Did you clear it?
15 usually means the signal or ground wire is open. Check the wiring by jumpering the harness terminals to see if it generates a 14. If not, check for 5 volts on the signal wire and check ground for an open. If you don't get the 5 volts, check for it at the ECM to confirm or rule out the wire. If it isn't at the ECM, you'll need a new ECM. Ground for most years is shared with the TPS and MAT, so if you don't have those codes, you only need to follow it back through the harness to the splice.
Old Jul 17, 2005 | 10:56 PM
qwiketz's Avatar
qwiketz
Clear it? I don't even know what that means. This is my first time running datamaster and my first problem with the car.
I'll check it for 5 volts next Saturday. 15 is the only code I'm getting right now. Everything else is green on the datamaster program.
Old Jul 18, 2005 | 12:27 AM
qwiketz's Avatar
qwiketz
on a side note... the check engine light went off when I changed the engine coolant temp sensor.
Old Jul 18, 2005 | 12:44 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Sounds like you need to clear the codes.
Datamaster will do this for you, although a bit crudely if you turn the key on, engine off and click Clean malf. in the Start stop monitor box
or you can pull the ECU fuse
Old Jul 18, 2005 | 12:46 AM
qwiketz's Avatar
qwiketz
awesome! I'll give that a try. I haven't seen that in the manual yet so I'll give it another once over.
thanks for all the help today!
Old Jul 18, 2005 | 09:04 PM
qwiketz's Avatar
qwiketz
update... the funny thing is when the sensor was not connected at all, the car would cold start fine and then run rich once it was hot because the sensor was reading about 30 some degrees. Now that it's fixed, the car starts like crap when cold (how cold could it be here in CA where it's 80* in the morning) and runs fine afterward once hot. When started cold now it idles really low and feels like it's not running on all 8 cylinders. This is so wierd....
To code 15- engine coolant temp sensor
