How often do wheels need to be balanced?
Old Jul 18, 2005 | 10:02 AM
FlyboyZR1's Avatar
FlyboyZR1
Default How often do wheels need to be balanced?
Pretty much as the title says, I had all 4 balanced when the tires were new and have put about 8,000 miles on them. I'm wondering if it's time to get them re-balanced to extend the life or just forget it since the tires won't last much longer anyways?
They are ZR-1 wheels on Sumitomo HTRZ tires.
Old Jul 18, 2005 | 10:32 AM
Nathan Plemons's Avatar
Nathan Plemons
Typically when you buy tires they recommend that you have them rotated and balanced every 6000 miles. Rotation of course assumes that you have the same size tire front to rear, if not you can't so much do that. When I bought my tires they come with free lifetime rotate and balance. Probably isn't REQUIRED per say, but it certainly wouldn't hurt anything. Its just good car maintanence practice that 99% of drivers in the world avoid.
Old Jul 18, 2005 | 10:35 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's good advice. Having said that, I'm going to try and remember to get mine done once per year.
However, if you are replacing the rubber soon and do not now experience vibration I would let it go till the new rubber goes on.
Old Jul 18, 2005 | 10:48 AM
FlyboyZR1's Avatar
FlyboyZR1
Well sometimes I get a slight vibration and by looking at the tread it appears I can maybe get another 10,000 miles on them so I think I'll go ahead and have them balanced.
Thanks guys.
Old Jul 18, 2005 | 10:59 AM
65Z01's Avatar
65Z01
In that case it's a good idea; you might also swap front/rear.
Old Jul 18, 2005 | 11:15 AM
rws.1's Avatar
rws.1
Find a Hunter Road Force Balancer.... they are the best.
Follow this link for one in your area
http://www.gsp9700.com/pub/search/FindGSP9700.cfm
Old Jul 18, 2005 | 11:50 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
The balancing advice and the Hunter Road Force Balancer, 9700 is/are great ideas. Depending on the tires, in some cases, just balancing them on a regular basis (not even rotating) can increase their lifespan. Good luck with it.
To How often do wheels need to be balanced?
