LT4 heads
Old Jul 19, 2005 | 02:14 PM
Lichen's Avatar
Lichen
Default LT4 heads
I'm getting ready to do a top end package. Probably will go with a LT4 Hotcam kit or something similar (have to pass emissions). Now what heads would you guys recommend. I thought about having the stock ones ported, but the local Corvette shop highly recommends that I go with new LT4 heads. Would this be a better choice? A much more expensive choice? EM would be doing the installation, I'm a mechanical idiot.
Old Jul 19, 2005 | 02:37 PM
Wildcat1's Avatar
Wildcat1
Is your engine an LT-1 or LT-4?
Old Jul 19, 2005 | 03:02 PM
STL94LT1's Avatar
STL94LT1
Getting your LT1 heads ported will outflow stock LT4 heads, and will cost about the same price as buying the new LT4's. But, if you are talking about porting the LT4 heads, that is a different story.
Old Jul 19, 2005 | 03:10 PM
Lichen's Avatar
Lichen
Sorry, I have a '93 LT1.
Old Jul 19, 2005 | 03:41 PM
LT4POWR's Avatar
LT4POWR
Stay w/ the LT1s. If you want more hp, get them ported.
LT4s in stock form don't justify the $ for the hp. LT4s also require the LT4 intake. Ported LT4s really aren't needed until you have a large cube and/or high rpm (big cam) motor.
Old Jul 19, 2005 | 03:49 PM
Lichen's Avatar
Lichen
Thanks, this is just the kind of guidance I'm looking for.
Old Jul 19, 2005 | 05:42 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yeah, bang for the buck the Stage III LT1 heads will do the job for most. Mine far outflow stock LT4 heads. 370 RWHP with Hotcam and stock bore & stroke, est. 425 or so at the crank. Hoping the stroker block I'm building will get me to at least 400 RWHP. We'll see.
Old Jul 19, 2005 | 07:18 PM
STL94LT1's Avatar
STL94LT1
Wow, seems like I just read that you dynoed 335 rwhp. Did the new headers make that big of a difference?
370 rwhp is really impressive from a Hot Cam in an A4.
Old Jul 19, 2005 | 07:28 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
SDPC2000.COM sells a CNC LT4 top end kit. LPE CNCs the heads for SDPC. comes with RR, Cam, intake, heads, everything you need... Price is 2900...
http://www.sdpc2000.com/catalog/3473...-CNC-Heads.htm
Old Jul 19, 2005 | 07:43 PM
Corvette Kid
Actually the initial number was 339, last fall. Hedman makes no headers suitable for D port heads (which all Vettes are, from '86L and up) and Bob at PP&C told me at the time I installed his heads that the non D-port headers would probably cost me as much as 20HP, since he concentrates on velocity and blocking the top of the D ports just kills that. Also I was running full stock exhaust sans cats at that time and had a couple of other minor glitches. The DRM headers are d-port design, obviously, and when they were bolted on along with the 2 3/4 mandrel bent (with no diminishing anywhere in size like the stock system) PE exhaust, the initial SOTP feel was truly astonishing.
BTW, I give Bob most of the credit for the power level. I know how to assemble an engine but the heads are where a lot of the magic is worked.
Old Jul 19, 2005 | 07:54 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
What he said... stock vs stock or ported vs ported, the LT4 heads are better in all aspects, however, to go LT4 in your situation, you'd have to buy the heads (an incurred expense) then port the heads (another expense) just to get a few cfm more flow than what you currently own. You'd be out $3k for a set of heads and that is a lot of mod money to be spent on other projects.
To LT4 heads
