Fuel Pressure Reading
Old Jul 19, 2005 | 04:02 PM
HGN CRVZ's Avatar
HGN CRVZ
Default Fuel Pressure Reading
I have read various posts and found the proper readings for the fuel pressure, but not the indications the gauge just indicate. My 87 when hot, is starting hard and stalling. I checked the fuel pressure and found the pressure at key on to be 45#, but when I start it the pressure becomes severely erratic. It jumps between 47 and 15 almost like a burnt intake valve does on a vacuum gauge.
I originally had a code 36 from the ECM. I conducted the flow chart tests and found nothing wrong with those ckt’s and the code has since disappeared.
Any help would be much appreciated!
Old Jul 19, 2005 | 04:42 PM
ittlfly's Avatar
ittlfly
Have you done the "key on, engine off" test on the fuel problem? If not, prime fuel system then pinch off supply line @ the fuel tank. If the pressure doesn't fall then the problem is in the pump / check valve.
Old Jul 21, 2005 | 09:19 AM
HGN CRVZ's Avatar
HGN CRVZ
A close inspection revealed a dry rotted vacuum hose to the fuel regulator and leaky injectors. Now to clean or replace?
Thanks for the help! It's amazing the knowledge and willingness to help.
Dan
To Fuel Pressure Reading
