Pulls right when braking.
Old Jul 20, 2005 | 10:34 AM
KZad's Avatar
KZad
Cruising
Default Pulls right when braking.
Been having problems with the 87's braking. When you hit the pedal, the car jerks (and I mean JERKS) to the right very badly. To the point that if you are not holding the wheel with two hands, you're in another lane.
This has been going on for a while now, and we've tried new calipers, pads, rotors, and properly bleed the system, all to no avail. We finally gave up and took it to a mechanic.
He told us that although he wasn't sure, he 'thinks' it's the ABS unit failing, and the he can replace it to the tune of like $1700.
Is there a test to see if this unit is bad? Anything else you guys can come up with? Can it be taken apart and cleaned? If this is the problem, where can I find a replacement at a good price? Are there similar units in other vehicles that I can find in a salvage yard?
Thanks for any information.
KZad
Old Jul 20, 2005 | 10:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't know of a test for the ABS but you might try Contemporary Corvette (link on my site) for a used unit.
BTW, when you replaced the front calipers did you also replace the caliper brackets?? You might try replacing the front brake hoses too.
Old Jul 20, 2005 | 10:27 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I had the exact same thing happen on my `76. The problem turned out to be that the brake hoses to the front calipers were collapsing internaly. Its caused by age. I replaced all four hoses ( one for each wheel ), & everything is fine. Another note: Steel braided hoses are rubber internaly, & could look ok, but still be collapsing. Also--- if it pulls to the right, it means that the left wheel brake line is collapsing, & vice versa.
Old Jul 21, 2005 | 08:47 AM
KZad's Avatar
KZad
Cruising
Oh nice, Contemporary Corvette is right near me - about 45 min drive. We did replace the front brake hoses, but what exactly do you mean by "caliper brackets"? I dont think we would have replaced them unless they come with the calipers. Should we look into that?
We havn't done much to the rear brakes. Mainly because the driver's side front rotor keeps warping (our guess is from getting hot because it's not releasing totally) and we figured the problem would be near that.
Any more ideas?
Old Jul 24, 2005 | 10:31 PM
KZad's Avatar
KZad
Cruising
Any other ideas?
Old Jul 25, 2005 | 01:07 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You might want to PM Mike_88Z51
He may still be able to diagnose the ABS modules.
Old Jul 25, 2005 | 07:21 AM
Bob CTS's Avatar
Bob CTS
Is the rotor warping even after you replaced the caliper? If so sounds like the caliper is binding and not releasing, I had this happen to a new caliper. I would replace the caliper especially if it still under warranty, see if that helps.
Bob
Old Jul 25, 2005 | 03:41 PM
jstkrsn's Avatar
jstkrsn
Last time that happened to me I had taken the right side and replaced almost everything. And it didn't help. Seams it was a leaky caliper on the left side. With fluid on the rotor there was no grab at all, so it pulled immediately to the side where everything was normal. Hope you checked both sides.
Old Jul 25, 2005 | 04:18 PM
1stC3Vette's Avatar
1stC3Vette
You should be able to completely disconnect the ABS system by unplugging it. If so, you should then make some stops from 30-40mph and see if the pull is the same. If so, the ABS system is ruled out of the equation.
The next step is to make sure that there is no residual brake pressure applied to the caliper when you are not pushing on the brakes. Again, make about 10 30mph stops at normal braking, then release the bleeder screw momentarily. The brake fluid should just dribble out, if it shoots out, then there is some residual pressure.
Good luck,
Dino
Old Aug 13, 2005 | 06:21 PM
KZad's Avatar
KZad
Cruising
Thanks Dino, that should help a lot.
I was just wondering how exactly do you disconnect the ABS system. Where do I start to look, or can I just pull the fuse?
thanks
KZad
Old Aug 13, 2005 | 07:18 PM
CMYC4GO's Avatar
CMYC4GO
thanks
KZad
Not sure where the fuse is, but there should be two wiring harness plugs on the ABS module. Unplug them both, and the entire system will be disabled. If it still pulls, then you can rule out ABS
Old Aug 13, 2005 | 09:39 PM
Frizlefrak's Avatar
Frizlefrak
I know this stuff is elementary, but sometimes we overlook the simple (and cheap) stuff....
OK....when you replaced the rotors, did you clean them with a good degreaser prior to installing? Many rotors are shipped with a thin coating of oil on them to prevent surface rust from forming....and if it's not removed, it will embed itself into the pads and ruin them....and cause pulling.
I would damn sure rule out everything else before shelling over $1700 hard earned bucks.
I know you bled them when you installed the new calipers, but is there any chance one of the lines still has air in it? Remember, air compresses, liquid doesn't. If a line has air, that caliper won't grip correctly. Since your car pulls to the right, start with bleeding the left side again. Are the calipers sliding smoothly? Any possibility a wheel bearing is starting to jettison grease onto the rotor?
Finally, any possibility that this is a tire issue....ie....tread separation?
I'm really leaning against an ABS issue here. I agree with the guys above....disable the system and see if the problem remains.
To Pulls right when braking.
