Coolant temp sensor grounding
Old Jul 22, 2005 | 02:24 PM
Roscoe's 85's Avatar
Roscoe's 85
Default Coolant temp sensor grounding
I changed the water pump on my 94 LT1. In doing so I took the old coolant temp sensor off the original water pump and put it on the new one. I used thread sealer on it. Is this bad? Does the coolant temp sensor on the LT1 need to be grounded through the threads. I have seen some intermitent check engine lights.
Old Jul 22, 2005 | 03:05 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
I did the same last year with no problems.
Old Jul 22, 2005 | 03:33 PM
pwrful c4's Avatar
pwrful c4
I used teflon tape with no problems.
To Coolant temp sensor grounding
