QA1 owners please step inside
thanks to all of you who helped me make my decision.
i placed the order at Summit yesterday morning & today they are already here!
a great start for the weekend!
before i install it tomorrow, i'd like to know if i will need a spacer/washer in the rear as rumoured. if so, any suggestions on what to use and the size? (ordinary stainless washer? bubble gum?)
For front I fabbed a bump stop of a couple of bushings that Naake was nice enough to send me. If you run 1 or 2 clicks in the front you probably won't need it, but I just wanted to be sure.
You might be able to use the stop out of some old oem Bilsteins but I'm not sure on the dia. of the hole.
did you use the mounting hardware that came with the shock? each shock included two 1/8" washers, two rubber donuts, jam nuts, and for the rears a metal sleeve for the bottom mount.
everything except for the metal sleeve looks like it is intended to be used at the top mount.
Also, are you lowered at all? If not, I would advise against it because the QA1s which are meant for the stock application do not have enough travel when the front is lowered. Mine is lowered 1-1.5" (didn't do a before/after) and I had to return mine for a shorter body. Naake was kind enough trade me even after I found out the hard way after a couple miles.
As for the rear, I just tack welded up three washers into a spacer... Worked just fine.
When I had my QA1s I ended up reusing the stock bushings because the ones they supplied were too small.
As for the rears I went to Home Depot and bought some 1/2" washers and opened up the ID a little bit using a Dremel tool. The problem is that the outside diameter of the washer (spacer) can't be much bigger than 1.25" from what I remember so measure carefully.
The QA1's are not a simple out of the box install, but I still prefer the adj. on the bottom & the extra work was not much. Kinda like when you build a race car, you end up fabbing a lot
I have no squeaks, rattles etc. & (as already stated) I adj them all the time for conditions as required.
www.naake.com are really nice to deal with.
the OD of the rear mounting studs were just over 0.61, so i got some 5/8" steel washers (couldn't find stainless at that size).
i installed the rears with the ***** facing forward first, thinking it looked cool. then the idot alarm kicked in. why face the **** towards rocks and gravel heading at it at 70MPH?
i re-used all the bushings and harware (except the jam nuts) on the fronts. i used all the hardware supplied with the shock for the rears, per shotchkiss' suggestion.
first tried 3 clicks from full soft all around. firm yet soft enough for daily driving (at least for me). added another 3 clicks to see what happens. i could feel every surface imperfection of the road. excellent.
at the harder setting, however, i get a squeak just behind me on large, gentle bumps. i think its the chassis (since it's probably twisting around a lot more) rather than the shocks. i'll probably grease the bushings anyway just in case in addition to a bolt check.
again, thanks for all the input.
I did a search on previous discussions on shocks and someone mentioned that QA1 had double adjustable shocks for a C4. I have only found one place that has double adjustables for a C4 for $325 a pop
. Probably the same shock since Carrera makes it but want to make sure.
Theyt have no front bump stops, for mine, I just modified one of the mounting grommets they send to slide over the front shaft so that the C clip wouldn't act as a stop.
For the rears, I just used 3 thick washers on the lower mounting stud after I enlarged the holes in them slightly to fit. If the holes are too big, the washers will slide off to the inside.
I put the ***** front - it seemed like it was easier to reach & adj. that way - but maybe not. Can you reach in easy & turn the **** from the rear?
So far no problems with rock damage.
call me paranoid, but here in MI we have a lot of gravel trucks, so i'm not taking any chances.
by the way, did you read that i already damaged the rears?
http://forums.corvetteforum.com/show....php?t=1144749
