Loosing Water...
Old Jul 24, 2005 | 03:32 PM
91vettemo's Avatar
91vettemo
Default Loosing Water...
Well I'm not sure where I'm loosing water at. The oil is not murky which is good, and its not dripping antifreeze anywhere. I did a compression test and it was fine. I replaced my water pump a few months ago. Any ideas on where to look next?
Old Jul 25, 2005 | 05:19 AM
fnseeker's Avatar
fnseeker
Default Try peplacing the cap.
How old is the rad cap its self? If the system holds pressure ok. The cap may be weak.
Old Jul 25, 2005 | 08:27 AM
RWDsmoke's Avatar
RWDsmoke
Sometimes a small leak on a hot engine will evaporate the water so it never reaches the garage floor. And it only leaks under pressure, as when the engine is hot. Autozone has a loaner radiator pressure tester. It has always worked for me to find leaks.
Old Jul 25, 2005 | 08:48 AM
conv90's Avatar
conv90
-Beppe-
Old Jul 25, 2005 | 09:07 PM
91vettemo's Avatar
91vettemo
Interesting, I will have to check it out. Thanks!
To Loosing Water...
