Valve stem seal recommendations? L98
Old Jul 23, 2005 | 12:29 AM
rodj's Avatar
rodj
Default Valve stem seal recommendations? L98
Any recommendation for valve stem seals (umbrella type) for '89 stock heads.
Looking at Summit / Jegs listing stem is 11/32, what is the stock OD ?
Have .500 + .530 listed.
Old Jul 23, 2005 | 01:22 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm not sure about the stock OD; I was very satisfied with performance of the OEM seals and didn't want any fitment issues either so I got a complete set of uppers & lowers from my local Chevy dealer for around $60.
Old Jul 23, 2005 | 12:56 PM
John A. Marker's Avatar
John A. Marker
Go with the Felpro "blue" seals. I also would suggest that you use the intake seals all the way around...use them on the exhaust too. This has been suggested many times in prior posts. I did this on my 85 ironheads and they worked great...NO PROBLEMS. I am now running new aluminum so I won't worry about that for awhile.
Old Jul 23, 2005 | 10:47 PM
JETSET's Avatar
JETSET
Default machining
Many of those valve seal need the top of the valve boss machined to accept them.
Make sure you get stock replacements if your not removing the head and machining the boss.
I have aluminum head I had machined for teflon seals
then they snap on to the boss and the valve slides inside the seal.
Old Jul 24, 2005 | 01:05 AM
rodj's Avatar
rodj
Thanks for the info.
Heads are "113s" on my old 95K motor.Didn't bother to change seals when ZZ4 cam / LT4 springs went in so now trying to solve smoke only at hot idle problem until new 383 built.
Embarrasing sitting the staging lanes with more smoke from exhaust than tyres.
To Valve stem seal recommendations? L98
