Please Help MAF problems
Old Jul 23, 2005 | 07:51 PM
DVS 99's Avatar
DVS 99
Default Please Help MAF problems
Please help me. My 88 vette keeps throwing code 33. I cant fix it. I replaced the MAF sensor 3 times and still does not fix problem. Dont know whats wrong. I heard the K&N filter oil can mess with it so I cleaned the element and installed dry and code 33 still sets. Does anyone have a suggestion?
Old Jul 23, 2005 | 08:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Replace the MAF power relay, located behind the battery on the firewall.
Old Jul 23, 2005 | 08:28 PM
richdwyer's Avatar
richdwyer
There are 2 relays, the maf power and maf burn off relay.They are both on the same bracket behind battery. They are under $10 each so you may as well replace both.
Old Jul 23, 2005 | 08:29 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Replace both power relays at the same time, per Gorden Killebrew and personal experience, if you don't you will have a repeat of the problem
Also, and again Gorden helped me with this down at Cruise In VI. two things can occur
1) dirty connections where the harness mates with the MAF sensor and
2) loose pin connections inside the harness.
To take care of #1, liberally spray the connections with electical contact cleaner or 93% isopropyl Alcohol
To take care of # 2. take a very small pick and kind of tighten up the female sockets
Personally. I would do both
Seeya
Old Jul 24, 2005 | 05:00 PM
DVS 99's Avatar
DVS 99
Already replaced relays.
Old Jul 24, 2005 | 08:13 PM
65Z01's Avatar
65Z01
Check the TPS as the ECM is also looking at the throttle position and comparing with MAF reported air flow.
Does the ECM throw the code at startup, at warm idle or during cruize??
To Please Help MAF problems
