How Hard To Install Starter
Old Jul 23, 2005 | 09:23 PM
07blkvette's Avatar
07blkvette
Default How Hard To Install Starter
Think I Need A Starter, How Hard Is It And Where Is The Best Place To Buy One.
Old Jul 23, 2005 | 09:26 PM
Bruce's Avatar
Bruce
piece of cake. Just losen up the the starter ans solenoi wires and a couple of bolts that is.
Old Jul 24, 2005 | 01:10 AM
rodj's Avatar
rodj
Disconnect battery first.
Get front of car high so you have room to access from below,Then as above.In some cases a shim is needed to achieve correct alignment of the pinion to flywheel with a new starter
Old Jul 24, 2005 | 02:23 PM
pwrful c4's Avatar
pwrful c4
This is good info.
Old Jul 24, 2005 | 09:12 PM
Yellow95's Avatar
Yellow95
There are 4 or five bolts/nuts to remove. Four different sizes, at least one is metric. The starter is heavy. I couldn't remove the upper wire while the starter was in place (maybe I could now since I know what it looks like). When I removed the two big bolts that hold the starter, that is when I found out the little nut on the top wire was metric. Luckily I had put the various wrenches in a coffee can when I went under the car. I used the can to hold the starter while I crawled out to get the %%$$@@ metric wrench. Other than that, it was a piece of cake.
There is a gasket between the starter and the engine. The new starter does not come with one. Try to get one before you start.
Tell the wife it is a three hour job, use the last two to polish off a six-pack.
Old Jul 24, 2005 | 10:44 PM
RocketSled's Avatar
RocketSled
If you've got an automatic, you'll be able to set the starter on the tranny cooler lines while you pick your nose/get your bearings.
I then used a prybar to move the lines to the side and rotate the starter through the gap.
Old Jul 24, 2005 | 11:40 PM
lawcorvette's Avatar
lawcorvette
I was doing this last weekend...shouldn't take long.... I got interupted by the rain. But I can see that on an auto the cooling lines to the transmission can get in the way, so try to jack the front end up pretty high to give yourself room to be comfortable.
I have a 7 quart pan in my vette and the combination of the pan and the lines were being a pain and it started raining on me so I had to seek shelter.
HH
Old Jul 28, 2005 | 06:28 AM
07blkvette's Avatar
07blkvette
thanks for the help guys, took me about 30 minutes car starting fine.
To How Hard To Install Starter
