OMG!! Electronic problem...what should I do?
Old Jul 25, 2005 | 01:20 PM
kpforce1's Avatar
kpforce1
Default OMG!! Electronic problem...what should I do?
Alright... this is one of those holy sh*t things that happen. I started having some problems one day with my voltage being off and my guage cluster and additional guages shuting on and off. Knowing that the cluster will only function properly with the correct voltage, i figured I had a short some where because the car would run... until I shut it off and the battery would die in 10 min after being fully charged. I found that the wiring harness running to the starter had broken loose and fell onto my header... resulting in a nice gob of melted plastic along with melting 3 wires in half... two had either a diode or a resistor on them...
I don't have time to mess with this problem and I was going to take it to someone and have them fix it. Can I get replacement wires to fix the harness (or partially replace 1-2 ft of it down where it melted)?? HELP!
