AC Delete-Need help
Old Sep 7, 2005 | 04:19 PM
  #41
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Originally Posted by Mtrhd329
so how did you get the belt tight? i have tried this and experimented with all sorts of different belts and belt routings and it was still loose. maybe a way to adjust the alternator outward??
Take an old belt and cut it.
Then route the belt the way you want it and mark it.
Measure the new length and go to the parts store and order the new length.
Matt383
Old Sep 7, 2005 | 05:14 PM
  #42
RonRed89's Avatar
RonRed89
Originally Posted by luvmy92
MORE Performance has one for an LT1
Hey Mike, what's the deal with your valve covers with the MORE logo? Was that a custom job? Looks cool!
Ron
Old Sep 7, 2005 | 06:29 PM
  #43
ClarenceT's Avatar
ClarenceT
This thread kicks azz
I was going to order the one from GM parts direct after I ripped all my AC stuff out. I left the compressor in for the pulley while I look for a way to do the dummy pulley. These are some great ideas guys..
Old Sep 7, 2005 | 07:12 PM
  #44
Mtrhd329's Avatar
Mtrhd329
this sounds like a good idea. After the belt is rerouted can you just start removing the a/c compr. and cond. or do you have to drain or purge it first. Also the belt number for this is 060670 right?
Old Sep 7, 2005 | 10:56 PM
  #45
Bob86ZZ4's Avatar
Bob86ZZ4
Chucks88 and Matt are right on the money. I got my advice from Doug Rippie (I am only 40 minutes from them so easy to get advice in person). Just simply remove the a/c, route the belt around the tensioner the other way. I did this on my car probly like 4 years ago and it's been fine. And, I beat my car pretty severely. I think the size belt I ended up with was a 735k6. But, it was easy to just cut the belt, wrap it around the way you want it routed, and overlap the end. Then make a mark where it overlaps. Then take that to the parts store and put it on their belt measurer. Then I told him I wanted one 1/4" shorter just for good measure. Chuck's pictures are great, that's exactly the way mine is. That looks like my car as a matter of fact, I even have the same intake and valve covers. Hay Chuck, did you take those pictures of my car? Good luck. Forget about ordering brackets and pulleys and junk. Lose the weight, parts to fail, resistance, etc....
Old Sep 7, 2005 | 11:00 PM
  #46
Bob86ZZ4's Avatar
Bob86ZZ4
Ha, that was a picture of my car. I thought it looked familiar. I just found it:
Old Sep 8, 2005 | 12:22 PM
  #47
chucks88's Avatar
chucks88
not my motor. I just posted those for Matt383
Old Sep 8, 2005 | 03:45 PM
  #48
Bob86ZZ4's Avatar
Bob86ZZ4
Not a problem, Chuck. I'm glad you had them.
Old Oct 12, 2005 | 08:45 PM
  #49
dbaker's Avatar
dbaker
Will this same routine work on the 85?
\dbaker
Old Oct 12, 2005 | 09:33 PM
  #50
Big_John's Avatar
Big_John
Originally Posted by 89 Paul in Cal
Let me add my pics too:
On the 89, 90 and 91 models, we don't have the small harrison A/C compressor, but the large nippon denso unit. This fact doesn't affect the belt routing, but is more reason to get rid of that big ole compressor.
Jesse ski_dwn_it can do this one better as he is using an electric water pump. Maybe he'll add his pic here.
As far as belt grip wrapping around the water pump pulley, it's plenty fine.
What do you do to adjust belt tension?
Old Oct 13, 2005 | 04:50 AM
  #51
pablocruise's Avatar
pablocruise
I remembered how all the old camaros and chevelles etc etc tensioned their belts: with a slot on the alt bracket. So I fabricated an alt bracket with a slot. All the guys with smog pump eliminator brackets could possibly get rid of their tensioners and the bracket the tensioner is mounted on if they modify their alt brackets to a slot design somehow. The companies that make the eliminator kits can change their current design and incorporate the slotted hole idea to their brackets too.
(I responded on the other thread also....sorry I'm late, girlfriend wanted attention )
Old Oct 14, 2005 | 10:34 AM
  #52
Matt383's Avatar
Matt383
You sent those to me about two years ago!! And I sent them out to others!!
Matt383
