weld wheels?what size?
Old Jul 26, 2005 | 05:40 PM
flatlne's Avatar
flatlne
Default weld wheels?what size?
1990 what size welds?backspace?
Old Jul 26, 2005 | 05:43 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Can you be more specific?
Larry
code5coupe
Old Jul 26, 2005 | 05:53 PM
flatlne's Avatar
flatlne
drag setups what are you guys running?
Old Jul 26, 2005 | 09:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
I think Mojo has the info you need. Pretty sure he ran them awhile back.
Old Jul 26, 2005 | 09:29 PM
pablocruise's Avatar
pablocruise
15 X 3.5" fronts. No backspace. You will have to use a spacer 7/16" and grind the caliper fins.
15 X 10" rears, 7.5" backspace. I use a spacer back there also.
Longer wheel studs and weld's extra length shank nuts are very good ideas also.
Old Jul 26, 2005 | 09:35 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
For the front(with 12" rotors) Weld ProStar in the 15 x 3.5 size with a 165/85R15 tire, for the rear Weld ProStar 15 x 10 with 7.5" backspacing and a 5/16 spacer with a 275/50R15 tire.
These size tires are the closest to duplicating the stock tire diameter.
Don't forget longer studs(68mm) and the proper lugnuts.
If you have J55 brakes, you may need a spacer for the front, I believe it's 5/16 as well.
Old Jul 26, 2005 | 10:07 PM
flatlne's Avatar
flatlne
Thanks for the info guys its nice to be out here on the forum
To weld wheels?what size?
