still stranded
Old Jul 26, 2005 | 08:57 PM
Top91Less's Avatar
Top91Less
Default still stranded
91 L98... Problem: running for 30 seconds and still stalling everytime.... OR if i give it gas it loses power, let the gas go..regains power..THEN stalls. Changed the fuel pump 2x, fuel filter,cap, rotor, clean air filter..lotta noise commin from the air intake area... could it be a throttle body sensor?...anyone with ideas before i give in and have her towed 45 miles =/
Old Jul 26, 2005 | 09:45 PM
chucks88's Avatar
chucks88
I guess I would try to trace down that noise first. Have you thrown on fuel pressure guage on your shreader valve to get some readings there?
What kinda noise are we talkin' 'bout? under what conditons? does the noise change?
Old Jul 26, 2005 | 10:48 PM
jfb's Avatar
jfb
Remove the flexible air hose from the front of the MAF and see how it runs. You might have a restriction in the air filter path. Measure the fuel pressure and watch it when you open the throttle. It should hold pressure. If not, you have a fuel delivery problem, or even a leaky injector/s. After turning the ignition off, watch how long the fuel pressure holds. If it drops rapidly you can have a leaky injector or defective fuel check valve. Any flexible tubing in the fuel path may be collapsing shutting off the fuel, check for that. Another cause may be a clogged catalytic converter.
Old Jul 26, 2005 | 11:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When you open the throttle you are leaning the mixture and when you let off you richen it up.
First check fuel pressure during idle and just before it stalls.
If pressure is ok, check the connections to the MAP sensor. It may be that the MAP is not registering manifold vacuum properly. To this end also check for a cracked or loose vacuum line.
Old Jul 26, 2005 | 11:29 PM
Top91Less's Avatar
Top91Less
ill be checking most of these suggestions in the a.m....after i get myself a fuelpressure gauge (anyone know of normal readings)..let's see where this lands me...rthanx for the input, keep em commin if ya can
Old Jul 27, 2005 | 01:47 AM
ZD1's Avatar
ZD1
stock is 36-38psi > Might be 42
I have mine set at 46 psi
Old Jul 27, 2005 | 02:13 AM
skeet's Avatar
skeet
intake manifold vaccum leak?
Old Jul 27, 2005 | 03:28 PM
theguardian's Avatar
theguardian
Default Did you...
Did you redo timing w/o opening the bypass circuit? If there's noise coming from the intake area, does it lessen as the throttle opens? Is the noise greater on the passenger or the driver's side? Has the EGR valve under the middle of the plenum come loose? What about the TB gasket?
Good luck.
Old Jul 27, 2005 | 03:58 PM
Top91Less's Avatar
Top91Less
thanx for all your suggestions guys..it's 105 degrees outside, feels like 125+ on the blacktop, so i broke down and had her towed to "Vette Doctors"....... I appreciate the time for reply's
Old Jul 28, 2005 | 10:06 PM
Top91Less's Avatar
Top91Less
they called n said it was the injectors....does thatmean ALL 8 went at once??? they will call me in the morning wih more info.....what's anyones take on it?
Old Jul 29, 2005 | 01:27 AM
smross33's Avatar
smross33
No way did all 8 injectors go bad at one time but if you're going to buy new ones you might as well get a whole new set of 8. Another option would be to send them away to someone like www.witchhunter.com and have them tested ,cleaned, and basically rebuilt for allot cheaper. I sent mine there and couldn't have been happier with their service.
Old Jul 29, 2005 | 10:02 AM
hz900's Avatar
hz900
Originally Posted by smross33
No way did all 8 injectors go bad at one time .
I would be very skeptical of that. If you let them change that get it in writing that if that does not solve the problem that you get your money back. If they are so confident that is it they SHOULDn't have a problem with that.
I had one do the exact same thing you are talking about and this was the cause. Had to tear down the entire intake and replace the manifold gaskets and all the vacuum hoses to fix it because I nor a mech. friend could isolate where it was leaking. Only thing is in order to change the injectors you have to tear it half way down, and they are liable to fix the real problem in the process and not know it.
Old Aug 3, 2005 | 08:19 AM
Top91Less's Avatar
Top91Less
well, finally got her back....it's not the same car i sent in...sounds different (meaner), runs faster-more power, idles smooth and excellent. i thought it was very pricey- cost 820 for 8 injectors, 8 plugs and an oil change. BUt now that she's running so good, I am very happy (although it's burnin gas a lil faster) .....thank u all for your input, very appreciated.
To still stranded
