LT1 vs LT4
When Car & Driver tested the LT4 in 1996, they turned the same quarter mile time as the last LT1/MN6 they tested. (in 1993, IIRC)
My opinion is that from idle to the LT1's redline, the engines are pretty much equal. The advantage for the LT4 is that last 500rpm pull.
Maybe your LT4 feels weaker than a stock LT1 because of the LT4's "mods".
Hey, it wouldn't be the first time.....
BTW, "quality" or strength of spark has no influence on power output. If the existing spark ignites the mixture at the right time, that's all it can do. Also, don't put too much stock in the buttdyno. Very few are that accurate....
Unless you have a real dyno on which to compare the two cars, the best way to compare them is a 30-130mph, side-by-side pull in third gear...and even that will be influenced (as will the buttdyno) by rearend gearing.
The bottom line: the LT4 does make more power than the LT1, but not much and only very near the redline.
Larry
code5coupe
Well let me tell you it does make a differance in the spark because of several different reasons.....I would check to see if the plug wires have been changed because I have a LT4 and I looked at the plug wires at night in the dark and it looked like a light show.....The wires break down over time and you will still get fire at the plugs but it may not be the correct amount of fire and that will cause the fuel not to burn commpletly and you will not get the full power out of the fuel that is burned! My LT4 had 110k miles with the original opti as well. I have changed wires and the opti and it made a big difference. If you cant burn "all" of the fuel then you will be down on power.
WTH??? Spark Strength has no influence on power output??? Well I guess I have been wasting my time and money on all those Malory, Jacobs, MSD and Accel ignition systems with the "hotter coils" ... Man what a conspiracy this must be, all those aftermarket companies selling stuff that has no influence on an engines power output..
Of course ignition strength has an influence on power... weaker sparks won't ignite all of the mix and thus not produce as much power.
So, if you engine is working fine and not misfiring, putting a high output coil isn't going to do squat for you. Put our stock ignition systems on a race engine with 13:1 compression and 8500rpm red line and it'll misfire like a SOB.
Plus the original LT4 plugs are known for loosing the platinum "hocky" pucks.....
Does your buddy's LT1 have a 160K miles on it........
BTW LT1 & LT4 are very close in engine torque below 4000 rpm, but LT4's torque stays up while LT1's falls off........if you are racing you want to shift the LT4 right at redline and all things being equal it will beat the LT1 easily........
Use your uprated ignition stuff to replace old parts, control redline, whatever, but I _seriously_ doubt if you've got a mild to stock motor that it's making ANY difference.
95 LT1 6spd
rearwheel horsepower 265
rearwheel torque 295
0-60 4.9
1/4 mile 13.3@104
96 LT4 6spd
rearwheel horsepower 300
rearwheel torque 305
0-60 4.7
1/4 mile 12.9@108
those are "best average numbers,any better than those,and they are factory freaks IE Mojo
of course,they could be worse,depending on production tolerances etc.both cars are pretty even up to about the 1/8 mile,then,The LT4 pulls away.BTW,the LT4's I've driven felt like they had a tiny bit better throttle response.
Engine wear is my first opinion. that puppy needs refreshening. Not putting down Lt1s but an LT1 should NOT feel stronger than your car especially if yours has mods.
A stock Z28 passed us both. The Z28 gave up just a little on the backstretch but got us both in the road course. The Z28 had 1 1/2" torsion bar, slicks, and upgraded brakes.
Bottom line; one is not going to tell a whole lot of difference in stock trim and with street tires/alignment between LT1, LT4, LS6 and LS2 in real world. Fractions of a second are just that; fractions of a second!
Upgrades make all the difference in the world.
