wats this thinger? (pic)
Jul 29, 2005 | 02:15 PM
has antifreeze dripping from it and its on the line labeled "heater" going into the firewall. Pressure sensor of some sort?
http://premium1.uploadit.org/illines...histhinger.jpg
Jul 29, 2005 | 02:33 PM
Cruise-In II Veteran
Not sure,but here's the pic for you
Jul 29, 2005 | 02:37 PM
I believe it is the heater core valve, I think it opens when you have the heat on. I could be wrong on this.
Bob
Jul 29, 2005 | 02:39 PM
From: What do I know anyway? I'm just a 50 year old No0b
Looks like a heater control valve to me. Vacuum operated off your climate control inside the car. Only allows coolant through the heater core when the heat is actually on.
Jul 29, 2005 | 02:47 PM
ty for the pic ramrod, but i just linked cause i didnt want to break the forum frames.
it looks like the part thats leaking is connected to the other hose. Like, the vacuum part that moves in and out is connected to the top hose and the moveable part is connected to a valve on the bottom hose. I think the valve must be leaking....
but anyways the real question is, is it all one part that both hoses plug into or 2 seperate or what? my chiltons has no answer...
:doom:
Jul 29, 2005 | 03:03 PM
You need one of these...
Jul 29, 2005 | 03:07 PM
Quote:
gack! 88$ is more than i make in a year (at the current time, barring new job)
which is why I choose instead to use one of these....
http://forums.corvetteforum.com/index.php?
seriously i'd like to have one but im trying to delay the 90 dolla hit until later if i can.....
Jul 29, 2005 | 03:31 PM
Ha... should change the forum title on top of internet explorer from C6 forum|2005 Corvette|blah... blah to Corvette forum - the economical alternative to a shop manual!
Jul 29, 2005 | 04:04 PM
St. Jude Donor '06
The two resources work great together, don't they?
Jul 29, 2005 | 04:42 PM
If things are really that tight, simply eliminate the heater control valve. My car hasn't had one for over 18 years, and I've never missed it.
If you
CAN scrape the $90.00 together, it will save you
WAAAAY over that, in farmed out repairs and in replacing parts that
AREN'T defective.
RACE ON!!!
Jul 29, 2005 | 06:22 PM
Keep an eye out for one on ebay or here on the forum. If you plan do much work on your car yourself, they are worth their weight in gold.
Jul 30, 2005 | 12:27 AM
Try
www.vette2vette.com I bought one from him a while back.
