Im stuck as the drivers side header keeps binding when i try and put it in from the top and the bottom isnt going in either. Before i rack my nuckles more and scratch the fine BBQ Black paint job, I was wondering how others with LT1 had done this.
If they're long-tubes then you may have to reverse an engine mount bracket bolt. When installing Exotic Muscle headers it's a key step. It may also apply to other brands.
LT Headers go in from the bottom and you have to reverse the motor mount bolt on the driver's side. After doing so, slipping in the headers should be fairly easy especially on the drivers side.
from the bottom is the only way. (well at least it was like that with both of my header installs)
and yes those dang motor mount bolts get in your way if you are wondering y it wont go all the way in. just be patient and itll be money.
if you are worried about paint then cover the headers with paper and have a friend help you from above while you slide it up from the bottom.
and before you get the header bolted in scre the plugs back in. oh yea make sure the plugs r out when putting in the headers.
move the ac compressor, its 4 bolts and then it will swing out of the way. and move the ASR these should help alot
MAN o man I see youre in Victoria.
and I jsut got back from vancouver about 3 weeks ago.
w took the ferry from twassaansen or whatever to victoria.
I love it there! we drove up to nanaimo. OMG it is so beautiful man!
I was thinkin about applyin to UVIC.
what do you think about it?
know anyone who goes there?
are you a native?
and in that case Id prob drive my vette up there and leave my DD here.
