Shock removal
Old Jul 30, 2005 | 06:27 PM
ziggyzz's Avatar
ziggyzz
Default Shock removal
HI all,
Need some help. I just went out ot replace the front shocks on my 92. Went to remove the bottom two bolts and it seems that the retaining nut on the bottom, under/in the lca just spins in the hole. I don't see how I could get a socket on it. Open to suggestions.
Thank you in advance,
Rob
Old Jul 30, 2005 | 06:58 PM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
I forget the exact size (12mm), but yes a small socket will fit in there. Has to fit in there or you will never get them out! Just did it myself not too long ago.
You may have to clean out all the dirt, grease, & grime that has clogged up the hole to get the socket in there!
Ron
Old Jul 30, 2005 | 06:59 PM
froggy47's Avatar
froggy47
You need to do whatever to get a socket on it. Remove wheel, jack under a arm, etc.
Old Jul 30, 2005 | 07:34 PM
ziggyzz's Avatar
ziggyzz
Hi,
Thanks for the ideas. I will give it another shot in the morning. I will let you know!!
Thx again,
Rob
Old Jul 31, 2005 | 03:09 AM
Mo_Bandy's Avatar
Mo_Bandy
ziggy,
as posted above, use a socket on the bottom I was thinking it was a 10 mm but it could be a 12mm ... and i use a wrench on the top, they will pop loose...
Mo
To Shock removal
