Finally, my Delteq kit arrived and I am Installing it!
It seems almost easy but i still have to remove the spark plug wires.
Passenger side does not seem that difficult.
Driver side seems impossible!
I have the water pump, optispark and balancer down because the original problem was the Optispark.
Can you share a trick to remove this wires without cutting them? I want to save them for later.
Thank you!
Thank you!
Completely loosen the power steering pump mounting bolts. You don't need to pull them out of the pump, or to remove the pump from the engine, but you do need to spin the bolts completely free of their mating threads. You don't need to remove the hoses from the pump. But you will need to move the PS pump around a half inch forward. Then you can fish the wires out of there.
Finally!
This was really difficult.
I tried everything except removing the PS pump.
That would be the best way because there is a metal tube that connects with the PS Pump and that is was will not let the spark plug wires ends to pass .
I have always just bent a coat hanger and made a hook in one end that would fit over the neck of the plug but was too narrow for the boot to slip thru. Fish it over the plug neck and tug.
When you replace them put some dielectric grease on the neck of the plug. It will make subsequent removal a lot easier.
Don't know what year your driving, but on the 95 LT1, remove the panael in the wheel well and the belt tensioner and they are exposed.
Once the tensioner is pulled you can get at them.I did not remove the whole wheel well assembly just the center piece.It just helps to get access behind the acc bracket.
It also helps to remove the bolts that secure the ASR unit's mounting brackets so that you can move the ASR unit around a bit so that it's not so much in the way all the time.
