brief stall when slowing down
Some times they just get carboned up, I'd pull it out and see if it is clean or not.
That should solve your problem...
Mo
Watch out for parking tickets at the shore. I got stuck for $35. for being 5 minutes late to feed the parking meter in Seaside Heights.
Kevin
Sounds like your IAC counts are out of wack, I would start by cleaning the IAC and the throttle body good. If that doesn't correct it I would put a scan tool on it and adjust the TB blades to see 20-30 counts at a warm idle. That will leave you enough room for the IAC to stay in range at all times.
Alvin,
