new cats?
Old Aug 2, 2005 | 10:51 AM
squalsvette's Avatar
squalsvette
Default new cats?
hey guys i have a 95 lt1 with 72000 i think my cats need to be replaced. What are some of the symptoms and if i do need to replaced what are the best kind to get and how much? How many miles do you get out of them?...thanx guys
Old Aug 2, 2005 | 11:35 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Clogged cats tend to reduce exhaust flow causing the engine to expend more HP expelling exhaust gasses, which is first felt as a loss of power at high RPM.
For a little boost in both power and mileage, when it's time, install hi-flow cats as your stock cats are rather restrictive.
Old Aug 2, 2005 | 03:15 PM
4REGT4's Avatar
4REGT4
"rather restrictive"?? - From what I have understood is that the LT1 cats are not very restrictive, and that you will not gain much power from a hi-flow cat. However, the L98s are in fact rather restrictive and hi-flow cats make for a worthy gain in power.
Old Aug 2, 2005 | 05:57 PM
yellow dragon's Avatar
yellow dragon
the newer the cat the less restrictive they are, i was told by my local muffler shop that high flow cats would maybe give you 5 HP on an lt1 or lt4, but 10-12 on an L98
Old Aug 2, 2005 | 06:19 PM
VenkmanP's Avatar
VenkmanP
CT has fairly stringent emissions doesn't it?
If so then you'll know to replace them when it fails the emissions test.
Old Aug 2, 2005 | 07:41 PM
MikeC4's Avatar
MikeC4
I just had new high flow cats installed on my '95 LT1, 69.5Kmiles. Here is the thread I started, and the symptoms I had....
http://forums.corvetteforum.com/show...11&forum_id=48
The muffler shop said they were damn near 100% clogged, which probably attributed to the fragging of my O2 sensors.
life expectancy probably a function of how well tuned the engine was during the 72K miles of operation....
To new cats?
