What could throw knock sensor code?
Old Aug 3, 2005 | 02:01 AM
craig0ry's Avatar
craig0ry
Default What could throw knock sensor code?
My car has thrown the knock sensor code since I bought it. I replaced the sensor and moved the wire and it didn't go away. Since the plug that attaches to the sensor looked like crap, I had 'vette to vette send me one. I cut the old one off, wired up this new plug, and still got the code. Tommorrow I am buying another knock sensor and I'm going to redo my wiring just to cover every possible base, but if that fails, I am completely stumped!
Anyone ever have this problem?
*And yes, I do disconnect the battery to clear the codes and it still comes back.
Thanks in advance guys,
-Craig
Old Aug 3, 2005 | 02:17 AM
Morley's Avatar
Morley
The ESC can also cause that code to appear
Old Aug 3, 2005 | 07:53 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The sensor could also be torqued in too tight or not tight enough. Check your Chevy service manual, but I think it's 15 lbs.
Also, if the sensor has any thread compound or tape on it, that could also make it throw Code 43. The orange coating that comes on the sensor is all you need when you bolt it in.
Old Aug 3, 2005 | 08:31 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Either real knock or false knock can cause the ECM to throw the code.
Real knock can come from too high engine temp, too much timing, low octane fuel, carbon build up on the piston, etc.
False knock can come from metal-to-metal contact, noisy lifters and, on '85-'88 L98s, a faulty ESC module. If the latter, check my site for the ESC upgrade P/N.
Old Aug 3, 2005 | 12:00 PM
CFI-EFI's Avatar
CFI-EFI
Usually the code is set by deviant activity in the system. Knock counts, real or false, are just the normal function the system. The code is triggered by a lack of voltage between the ESC module and the ECM. Usually it is a wiring connection or the ESC module, itself. The signal from the knock sensor causes the voltage from the ESC to drop. Therefore, if the code is due to the knock sensor, it is only because it is working, not failed. It pays to trouble shoot per your service manual before you throw parts (money) at a problem.
RACE ON!!!
To What could throw knock sensor code?
