Instant Low Coolant Light
Old Aug 3, 2005 | 08:14 AM
Casper's Avatar
Casper
Default Instant Low Coolant Light
Filled my radiator 2 twice now to the top but as soon as I start it the Low Coolant light comes on. I can not see any leaks. The light will go off when I do a little spirited driving. Oh, also there is never any coolant in the overflow tank.
Old Aug 3, 2005 | 08:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette???
On my '88 that tank is a resevoir that the cooling system continually takes coolant from and returns it to. Fill it to the indicated mark and things should settle out soon.
Old Aug 3, 2005 | 08:54 AM
Casper's Avatar
Casper
It's an '89. Plastic overflow tank. Maybe it's got a hole in it, because there is never anything in it.
Old Aug 3, 2005 | 09:49 AM
TripleBlack88's Avatar
TripleBlack88
I had a similar issue on my '88. It seems that there can be an air pocket in the system that you need to get out. I removed the radiator cap with the car cold, then started it and watched till the thermostat opened. The fluid level went down and I added coolant and then replaced the radiator cap. Haven't had a light since. It can get a bit messy so be prepared to hose down your driveway to get rid of any coolant that spills over. And, of course, when your engine reaches operating temperature the coolant is HOT so be careful.
Old Aug 3, 2005 | 10:10 AM
65Z01's Avatar
65Z01
If your coolant reseroir is, like in my '88, located below and to the right of the radiator it should be about 1/2 full of coolant.
You might pull it and verify that the filler hose and the spout into the resevoir are not clogged as well as check for leaks.
If all is well there you may have a problem with the radiator cap. The cap is designed to hold pressure to a specific set point but to allow the cooling system to pull up coolant when needed.
Then fill it with coolant to the mark on the stick upder the cap.
Old Aug 3, 2005 | 12:41 PM
Casper's Avatar
Casper
Good idea about pulling the overflow tank out. I'll try that as that should be cheapest fix.
Old Aug 3, 2005 | 04:09 PM
Square's Avatar
Square
I agree with his advice. I believe that the phrase you will see on the foum is "packing the radiator". As mentioned, start the motor cold with the cap off and when the thermostat opens have an assistant hold the motor at 2,000 RPM. The coolant level will drop a good bit. Top off the radiator while the motor is being held at 2K RPM, and replace the cap. I have a 160 T-stat, so I had a lot of time, if you have a 195, you will have to move fast. Do NOT let the motor go over 210 degrees with the cap off as coolant will start boiling out and it is a pain to get the cap back on by then and if you stop the engine or even drop back to idle, hot (very F'n hot!) coolant will come flying out of the radiator cap opening under pressure (don't ask how I know this ).
Be quick, be careful (gloves are a must) and you should be able to top off your radiator and never see the low coolant light again.
HTH!
To Instant Low Coolant Light
