Opti-Spark Problems...
Old Aug 3, 2005 | 08:42 AM
Garys Dream's Avatar
Garys Dream
6th Gear
Default Opti-Spark Problems...
Well, here I go again, damn it! I have another bad Opti-spark unit. After doing a little research, I discovered that ther was a TSB written on this optispark unit back in 1992. Now this is the second unit that has been in my car since I bought it 7 years ago, but the unit that is in there now, I put in not even a year and a half ago. And for those of you who have changed one, you know what a pain in the ars it is. Anyway, I need to find a new unit and was wondering if that dealership in Oklahoma, Superior Chevrolet I think, is still offering 10% over cost on there parts to COrvette Forum Folks. Does anyone out there know who I can contact?
Old Aug 3, 2005 | 09:31 AM
STL94LT1's Avatar
STL94LT1
Try Dal at Vandevere Olds, he was ~$30 cheaper than Superior on my opti.
1-800-362-9494
Chris 96 WS6's Avatar
Chris 96 WS6
I'd buy the Delteq opti eliminator if I were in your spot. Sure its pricey but you'll come out even in the long run because you won't be buying Optis every other year anymore.
http://www.delteq.com
Old Aug 3, 2005 | 09:41 AM
Roscoe's 85's Avatar
Roscoe's 85
I chose the Dynaspark system. It was a little cheaper than the Delteq and you can rebuild it if it breaks. However it is fully sealed and vented to prevent breakage. The Delteq still uses the opti to get a signal (low voltage side) so it really doens't eliminate it's need. It just eliminates the parts (high voltage side) that usually fails.
Old Aug 3, 2005 | 07:14 PM
SJW's Avatar
SJW
These are exactly the reasons I opted for the DynaSpark, too. So far, I'm very pleased with it after a year of use. I'd never install another OEM Opti, when there is a better choice in the aftermarket.
Be well,
SJW
To Opti-Spark Problems...
