Anti-Seize on O2 Sensor?
Old Aug 4, 2005 | 01:18 AM
GRX's Avatar
GRX
Default Anti-Seize on O2 Sensor?
Will anti-seize contaminate an O2 sensor? I usually use regular high temp anti-seize on the threads. TIA
Old Aug 4, 2005 | 01:22 AM
tjwong's Avatar
tjwong
I have never had a problem as long as you use it sparingly. It don't take much to get the job done. Just a light coating on the threads only is adequate. I also suggest using a marine grade nickel compound that is rated at 2200 deg F. The standard silver stuff from NAPA is only good to 1500 or thereabouts.
Old Aug 4, 2005 | 11:22 AM
chevyc4's Avatar
chevyc4
Just be sure not to get the anti-seize on the sensor part down at the bottom. I fried two O2 sensors this way.
Old Aug 4, 2005 | 11:34 AM
chucks88's Avatar
chucks88
I've been using a copper antiseize for the threads to my sensors. I believe that is what is made for.
Old Aug 4, 2005 | 11:36 AM
artvette's Avatar
artvette
Agree
Old Aug 4, 2005 | 12:01 PM
JAKE's Avatar
JAKE
I believe new ones come with a compound already installed on the threads.
Jake
Old Aug 4, 2005 | 12:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
On a related topic, the 02 sensors are generally easier to remove warm, not cold.
Old Aug 6, 2005 | 02:54 PM
GRX's Avatar
GRX
Tjwong - This stuff is super-duper strength! I found this on the net...note "nuclear fittings"!
NICKEL SPECIAL, NUCLEAR GRADE
""The standard in the nuclear industry, Never-Seez® Nickel Special, Nuclear Grade is specially tested and certified pure for use in nuclear power plants. Each production lot of Never-Seez ® Nuclear Grade is tested for contaminants of sulfur, halogens and low-melt metals and each container is labeled with the lot number that certifies purity. Recommended for nuclear fittings, valves and steam mani-folds. Provides maximum protection from high heat up to 2400ºF and aggressive chemicals. Meets General Electric D50YP12, Westinghouse and Bectel's nuclear specifications. Tested to MIL-A-907.""
Old Aug 6, 2005 | 07:15 PM
96dblblack's Avatar
96dblblack
Jake
To Anti-Seize on O2 Sensor?
