Cold air intake ideas..
But all the forced/cold systems seems have some quality problem or not proven results.
so I thought...
Why not cover (seal) the upper side of the lid (where the air is suked from) and open a rectangular hole just under the stock lid.
Then cutting the radiator shroud the air will be suked from the lower side of the stock lid...
It's a so stupid idea? it seems too simple... it's impossible no one tried this way...
-Beppe-
I don't believe any "cold air intake" can find colder air than that. So, at best it gets cool air into the engine few seconds faster but while you are moving it does nothing a open lid setup doesn't already do. So basicly the stock thing works like it is supposed to and in reality there is very little improvement offered by all those kits.
Ram air setup makes more sense IMO.
It is the style where the filter fits over a hole cut into the radiator shroud.
so I thought...
-Beppe-
I can take a couple pics of mine later tonight to post them up as well.
..I continue to see it on the online TPIS catalog ...
I knew that this system was available on the market because I seen this on the Raysur web site http://temp.corvetteforum.net/c5/raysur/index2.shtml
My original question is if is possible to do the same mods with the stock plastic piece.
Why not cut under the stock lid , cover it on top and cut the radiator shroud?? It seem so simple...
Why I need to spend $300?
-Beppe-
-Beppe-
It does seem simple, but it would actually take a couple cores and some trial and error to really get it right. I have to clean my air filter anyway in a couple days, if you want I can take some detailed pics of it when it's off the car so you can get a better idea of what it's like.
-Beppe-
but did you realise that the air filter needs to be on different side in these two systems? Air tube to TB is connected to the bottom half of the stock box ie. the clean side of the air filter box. If you just cover the top in stock box and cut hole in the bottom you effectively delete the air filter and blow your engine in short time. This is why they charge money for the systems. The boxes are designed and manufactured to accept the air filter in such way it works when the air comes from bottom side. And the air tube is again connected to the clean side ie. the top half of the box in this case.
Not very clear explanation but I hope you understand what I mean?
If you want to make your own system, figure out a way to direct ram air to the air filter box using tubing. I've seen some systems in the forum.
Well, the upside down -system you are thinking is also doable but needs more thinking and more advanced manufacturing skills.
so I thought...
-Beppe-
i am leaning towards the TPIS one, the quality, and the way it works just seems right. and there are a few members who have actually seen upwards of 15chp gains with it.
The project in my mind has the filter positioned under the plastic thing, relocating the metal cover under the plastic lid..
I know,.... when i will try to do this, I will see all the difficult that now I can't see
....my problems is taht I don't want to spend over $500 for a plastic piece taht is very similar to the original one.
Ciao!
-Beppe-
Ciao!
-Beppe-
its not anywhere close to $500 i thought
Corvette Cold Air Intake
This air intake reverses the direction of flow and provides cooler, denser air. At elevated speeds a positive pressure will be felt by the engine. Care must be taken in wet weather.
For every 10 degree drop in inlet temperature, approximately 1% more power is produced. On a 90 degree day we saw a 16 degree drop in air temperature at the 1/8 mile mark, in back to back testing.
This product is worth .2 seconds, and 2mph.
that is the quote from TPIS.
umm, for 85-89 it is $249. i think that system looks real good, i forgot you had a 90.
At 20 mph, I saw no difference in the outside temperature vs. intake temperature for the stock setup. Cool air gets up to the filter from the bumper area.
