Radiator fans
Old Aug 5, 2005 | 01:48 PM
wpsrea's Avatar
wpsrea
Default Radiator fans
I have a '92 LT-1. At what temp shoud the left(driver's side) fan come on? My right fan seems to be working OK i.e. comes on with the A/C. However, the left side does not seem to be working. Is there a relay or temp switch that comtrols it? Where might they be located.
Old Aug 5, 2005 | 01:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There indeed is a relay for each fan; the ECM usually runs only the primary fan, the secondary is for occasional use.
To test them jumper the ALDL pins A&B (upper right) with a paper clip and start the engine. The ECM should bring on both fans.
Old Aug 5, 2005 | 01:57 PM
audible's Avatar
audible
My 96 LT1 is set by the factory to come on at 226 or if the A/C is turned on.
wpsrea's Avatar
wpsrea
Thanks much. I'll give the test a try. I want to make sure they both are working.
Old Aug 5, 2005 | 02:08 PM
wpsrea's Avatar
wpsrea
I tried the "jumper" with a paper clip. The left side still did not come on. Maybe a relay? Where is it located?
To Radiator fans
